ArcGIS Runtime Local Server SDK 100.8 is now available for download from the ArcGIS for Developers site.
To update the Local Server version used by your projects you can update the `Esri.ArcGISRuntime.LocalServices` reference from 100.6 to 100.8 via NuGet.org or alternatively download from NuGet.org to the local Esri NuGet source created by the ArcGIS Runtime SDK for .NET Visual Studio extension (`%localappdata%\Esri\NuGet`) and then update your projects.
For more information see ArcGIS Runtime Local Server SDK 100.8 now available!
