How to show .dwg file in map control in arcgis runtime wpf
1646
6
06-28-2018 02:50 AM
LonrixLimited
Hi ,
How to show .dwg (CAD ) files in arcgis runtime wpf.
MichaelBranscomb
Esri Frequent Contributor
Are you using the WPF API included with ArcGIS Runtime SDK for .NET? If so, I'll move this post to the forum for that SDK.
Cheers
Mike
SalieghAziz
Hi @MichaelBranscomb was this moved, and solved for the OP?
MichaelBranscomb
@SalieghAziz This post wasn't moved because additional clarification was required regarding the exact product being used.
solved for the OP?
Please can you clarify the question?
SalieghAziz
@MichaelBranscomb My use case is slightly different. I'd like to be able to open a dwg file and interrogate it for certain objects (north arrow, scale bar, layer types, etc).
I've searched through the help documentation for both 10.2.x and 100.x, and have been able to find any reference. I might have to resort to writing some arcobjects 🙂
MichaelBranscomb
If you are using ArcGIS Runtime SDK for .NET and building a WPF app, you might be able to use the Local Server component and write a Python script and share as a Geoprocessing package.
The 'CAD to Geodatabase' geoprocessing tool is also supported in Local Server:
InsiaIftiqhar
How do you provide the license string to a local server?
