At Prerelease the new accelerated display functionality is dependent on having the DirectX End User Runtime installed. ...
There is some more information on this in the release notes: http://resourcesbeta.arcgis.com/en/help/runtime-wpf/concepts/index.html#/Release_notes_ArcGIS_Runtim...
Hey Mike, I've gone so far as to install the DirectX End-User Runtime, as instructed, but the Accelerated Map samples still crash on my machine. The error details are:Sample: LocalAcceleratedMap
Error: Accelerated Display failed to create. Please check DirectX end user runtime is installed. Also check the graphics drivers support Windows Display Driver Model (WDDM), note that standard VGA drivers do not support WDDM.
Stack Trace:
at ESRI.ArcGIS.Client.NativeMap..ctor()
at ESRI.ArcGIS.Client.DrawingSurface.CreateRenderSurface()
at ESRI.ArcGIS.Client.Map.OnApplyTemplate()
at System.Windows.FrameworkElement.ApplyTemplate()
at System.Windows.FrameworkElement.MeasureCore(Size availableSize)
at System.Windows.UIElement.Measure(Size availableSize)
at System.Windows.Controls.Grid.MeasureOverride(Size constraint)
at MS.Internal.Helper.MeasureElementWithSingleChild(UIElement element, Size constraint)
at System.Windows.Controls.ContentPresenter.MeasureOverride(Size constraint)
at System.Windows.Controls.Border.MeasureOverride(Size constraint)
at System.Windows.Controls.Control.MeasureOverride(Size constraint)
at System.Windows.ContextLayoutManager.UpdateLayout()
at System.Windows.ContextLayoutManager.UpdateLayoutCallback(Object arg)
at System.Windows.Media.MediaContext.InvokeOnRenderCallback.DoWork()
at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
Error: Object reference not set to an instance of an object.
Stack Trace:
at ESRI.ArcGIS.Client.DrawingSurface.SetSize(Int32 width, Int32 height)
at ESRI.ArcGIS.Client.Map.<Map_SizeChanged>b__d()
at ESRI.ArcGIS.Client.ThrottleTimer.<.ctor>b__1(Object s, EventArgs e)
at System.Windows.Threading.DispatcherTimer.FireTick(Object unused)
I've updated my display drivers to their latest version, to no avail. For what it's worth, I'm running Vista 32 w/ DirectX 10.Do you have any advice on other things I could try, or thoughts about what might be causing this problem?Thanks!Brooks
