Quality of rendered layers from mpks in Runtime not as good as in ArcMap
3404
03-27-2013 10:10 AM
by Anonymous User
Not applicable
Original User: mikechang
I created MPKs from MXDs and then displayed layers from the MPKs in Runtime.
All the layers in the MPKs are either local feature layers or local dynamic layers.
When I zoomed into a layer in Runtime, lines rendered do not look as sharp as they do in ArcMap.
Widths in the lines are not consistent, and some portions in a line look brighter than others in the same line in a constant manner.
Especially when lines are overlaid on top of photo images, this becomes a lot more obvious.
Even line symbology I set in ArcMap was altered to a random one when displayed in Runtime.
Since printing maps out of the Runtime app will be required in my case, preserving symbology at any scale is critical.
Is there any way to fix this problem?
Any replies would be greatly appreciated.
DavidMartin
One thing I'd try (at least it's a quick thing to test!) is to set SnapToDevicePixels = true on the Map.
by Anonymous User
Not applicable
Thank you for your reply. I tried it, but it didn't make much difference.
teamIgal
We are experiencing the same problem.
I think it happens when you use an MPK layer with the features on top of a TPK layer with the background image.
Is there any solution to this problem?
Thanks!
by Anonymous User
Not applicable
Original User: team.igal
Can we get any input on this?
Thanks.
