How to display rastermap(.tif) on the ArcGIS wpf
1701
01-17-2019 06:08 PM
MohamadFathin
HI
I still new in ArcGIS just try this ArcGIS trial for my project. How can i display a rastermap(.tif) on the ArcGIS using wpf? Is there any basic tutorial how to add the map view on the wpf?
Regards,
Fathin
MichaelBranscomb
Esri Frequent Contributor
Have you installed ArcGIS Runtime SDK for WPF and are have a project reference to Esri.ArcGISRuntime?
If yes, we recommend you install the later ArcGIS Runtime SDK for .NET and for WPF applications reference the Esri.ArcGISRuntime.WPF NuGet package.
To display a raster file (e.g. *.tif) use the RasterLayer class e.g. arcgis-runtime-samples-dotnet/src/WPF/ArcGISRuntime.WPF.Viewer/Samples/Layers/RasterLayerFile at mas...
Cheers
Mike
MohamadFathin
Hi Michael Branscomb‌,
Thank you for a reply i already install the ArcGIS Runtime SDK. I managed to display the one tile of raster map(.tif), but how can i display multiple tile of raster map on ArcGIS so that it will become full map and can rendered it?
Regards
Fathin
MichaelBranscomb
This Guide topic provides an example of how to use the MosaicDatasetRaster class: Add raster data—ArcGIS Runtime SDK for .NET | ArcGIS for Developers
Cheers
Mike
MohamadFathin
I already look at the link you shared, there is something i don't understand.
1.Did i need to use data management tool to change from raster to mosaic so that i can display multiple raster map tile in full map on ArcGIS?
2.It is possible to view all the raster map tile on the fly without using mosaic?
3.The MosaicDatasetRaster for online or local? Cause my program are all locally.
Regards,
Fathin
