Having Issue on Implementing MVVM with ArcGIS Runtime Local Server
1203
11-21-2018 12:17 PM
BehrouzHosseini
I am trying to setup a ESRI Local Server for displaying .mpk. I have a Model like
 public class Model
        private string basemapLayerUri = "http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer";
        private string mapPackage = "D:\\App\\Data\\Canada.mpk";
        public Model()  { }
        public string BasemapLayerUri
            get {return this.basemapLayerUri; }
            set
                if (value != this.basemapLayerUri)
                    this.basemapLayerUri = value;
        public string MapPackage
            get { return this.mapPackage; }
            set
                if (value != this.mapPackage)
                    this.mapPackage = value;
in ViewModel.cs Class I have
public class ViewModel : INotifyPropertyChanged { public Model myModel { get; set; }
    public event PropertyChangedEventHandler PropertyChanged;
    public ViewModel()
        myModel = new Model();
        this.CreateLocalServiceAndDynamicLayer();
    public string BasemapUri
        get { return myModel.BasemapLayerUri;  }
        set
            this.myModel.BasemapLayerUri = value;
            OnPropertyChanged("BasemapUri");
    public async void CreateLocalServiceAndDynamicLayer()
        LocalMapService localMapService = new LocalMapService(this.MAPKMap);
        await localMapService.StartAsync();
        ArcGISDynamicMapServiceLayer arcGISDynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer()
            ID = "mpklayer",
            ServiceUri = localMapService.UrlMapService,
        //myModel.Map.Layers.Add(arcGISDynamicMapServiceLayer);
    public string MAPKMap
        get { return myModel.MapPackage; }
        set
            this.myModel.MapPackage = value;
            OnPropertyChanged("MAPKMap");
    protected void OnPropertyChanged([CallerMemberName] string member = "")
        var eventHandler = PropertyChanged;
        if (eventHandler != null)
            PropertyChanged(this, new PropertyChangedEventArgs(member));
As you can see I am trying to implement the local server and dynamic layer in ViewModel.cs like
        ID = "mpklayer",
but I do not know how to bind this service to the Mode ? I tried
but as you know the myModel doesn't have any Map object. Can you please let me know how to fix this?
PrashantKirpan
Create Property in viewmodel.cs and bind it to map object in XAMl. After that you can pass Map object to your model class. Create Map object in viewmodel constructor.
Sample code:
 public Map Map { get; set; }
 public ViewModel()
        Map = new Map(new Basemap(basemapLyrs));
        myModel = new Model(Map);
 <esri:MapView x:Name="AppMapView" Map="{Binding Map}"
Regards,
Prashant
