Generate KML/KMZ
7447
12-10-2012 03:24 AM
De_WetEllis
Hi
Is there a way to Generate a KML/KMZ file using the ArcGIS Runtime SDK for WPF.
I tried using the local server but it doesnt support the GenerateKML operation. Or the f=kmz in the querystring.
Our Client just wants a simple Map application using a map package and then find a parcel and export to kml.
Any help would be appreciated.
De Wet Ellis
De_WetEllis
Hi all
I have found a free Library called sharpKml
http://sharpkml.codeplex.com/
"SharpKML is an implementation of the Open Geospatial Consortium (OGC) KML 2.2 standard developed in C#, able to read/write both KML files and KMZ files."
This is a great tool that makes writing KML files very easy.
Sample Code
            Document document = new Document();
            document.Name = "Polygon.kml";
            document.Open = false;
            int i = 1;
            GraphicsLayer graphicsLayer = _map.Layers["MySelectionGraphicsLayer"] as GraphicsLayer;
            foreach (Graphic grp in graphicsLayer.Graphics)
                OuterBoundary outerBoundary = new OuterBoundary();
                outerBoundary.LinearRing = new LinearRing();
                outerBoundary.LinearRing.Coordinates = new CoordinateCollection();
                ESRI.ArcGIS.Client.Geometry.Polygon pg = grp.Geometry as ESRI.ArcGIS.Client.Geometry.Polygon;
                foreach (ESRI.ArcGIS.Client.Geometry.MapPoint itn in pg.Rings[0])
                    outerBoundary.LinearRing.Coordinates.Add(new Vector(itn.Y, itn.X, 30));
                Polygon polygon = new Polygon();
                polygon.Extrude = true;
                polygon.AltitudeMode = AltitudeMode.ClampToGround;
                polygon.OuterBoundary = outerBoundary;
                //Color Style Setting:
                byte byte_Color_R = 150, byte_Color_G = 150, byte_Color_B = 150, byte_Color_A = 100; //you may get your own color by other method
                var style = new Style();
                style.Polygon = new PolygonStyle();
                style.Polygon.ColorMode = SharpKml.Dom.ColorMode.Normal;
                style.Polygon.Color = new Color32(byte_Color_A, byte_Color_B, byte_Color_G, byte_Color_R);
                //Set the polygon and style to the Placemark:
                Placemark placemark = new Placemark();
                placemark.Name = "place" + i.ToString();
                placemark.Geometry = polygon;
                placemark.StyleSelector = style;
                //Finally to the document and save it
                document.AddFeature(placemark);
                i++;
            var Mykml = new Kml();
            Mykml.Feature = document;
            KmlFile MykmlFile = KmlFile.Create(Mykml, true);
            MykmlFile.Save("C:\\MyPolygon.kml");
Hope this can help someone out in the future.
Regards ,
De Wet Ellis
KevinHibma-old
Regular Contributor III
As you've probably already determined, the (from/to) KML tools arent supported in the Runtime.
In core ArcGIS, either the tools or using the output from Server with type of KML is the only way to create KML. (or extensions like data interop)
I havent personally used any of the C# KML packages listed here, but one might provide a useful option?
Or there might be a script tool out there which writes KML. If you can find a script that someone has already written you can wrap that in a geoprocessing task.
De_WetEllis
Hi Kevin
Thanks for the reply. I will look into the suggested options.
If I find a solution I will post it here.
In the mean time .. If someone has a solution already. Dont hesitate to reply :p
Thanks again .
De Wet Ellis
De_WetEllis
Hi all
Sample Code
            int i = 1;
                i++;
Regards ,
De Wet Ellis
