Hello, I'm using Arcgis SDK for WPF version 2.4. In my application I create a dynamic, on-the-fly simple GraphicsLayer - each graphic in the GraphicsLayer has a timeextent attribute that is given at the time of its creation. I'm trying to bind the GraphicsLayer to a TimeSlider control by code (like this example, but in wpf and using a graphicsLayer) - I'm setting a timeextent for the map and going through all the steps, but the Graphics aren't binded to the slider. Am I doing something wrong? How can I get it to work? any advice will be welcomed.Thanks in advance. Enclosed is my source code:using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Data;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Imaging;
using System.Windows.Navigation;
using System.Windows.Shapes;
using ESRI.ArcGIS.Client;
using ESRI.ArcGIS.Client.Geometry;
using ESRI.ArcGIS.Client.Symbols;
namespace timeSlider_FeatureLayer_09092013
/// <summary>
/// Interaction logic for MainWindow.xaml
/// </summary>
public partial class MainWindow : Window
public MainWindow()
InitializeComponent();
private void btnGo_Click(object sender, RoutedEventArgs e)
var intervals = new List<DateTime>();
Graphic g = new Graphic()
Geometry = new MapPoint(200000, 600000),
Symbol = LayoutRoot.Resources["MySmallMarkerSymbol"] as Symbol
var dt = Convert.ToDateTime("01/01/2011 11:11:11");
g.Attributes.Add("myDt", dt);
g.TimeExtent = new TimeExtent(dt);
intervals.Add(dt);
eventGL.Graphics.Add(g);
g = new Graphic()
Geometry = new MapPoint(180000, 600000),
dt = Convert.ToDateTime("02/02/2012 12:22:22");
intervals.Add(dt);
g = new Graphic()
Geometry = new MapPoint(200000, 580000),
dt = Convert.ToDateTime("03/03/2013 13:33:33");
intervals.Add(dt);
testTS.Intervals = intervals;
DateTime dtMin = Convert.ToDateTime("01/01/2011 08:00:00");
DateTime dtMax = Convert.ToDateTime("03/03/2013 17:00:00");
testTS.MinimumValue = dtMin;
testTS.MaximumValue = dtMax;
testTS.Value = new TimeExtent(testTS.MinimumValue, testTS.MaximumValue);//MinimumValue.AddYears(3));
testTS.DataContext = eventGL;
testTS.Loop = true;
TimeExtent te = new TimeExtent();
te.Start = dtMin;
te.End = dtMax;
g.TimeExtent = te;
<Window x:Class="timeSlider_FeatureLayer_09092013.MainWindow"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:MY="clr-namespace:timeSlider_FeatureLayer_09092013"
xmlns:esri="http://schemas.esri.com/arcgis/client/2009"
xmlns:esriToolkitPrimitives="clr-namespace:ESRI.ArcGIS.Client.Toolkit.Primitives;assembly=ESRI.ArcGIS.Client.Toolkit"
Title="MainWindow" Height="350" Width="525">
<Grid x:Name="LayoutRoot">
<Grid.Resources>
<esri:SimpleMarkerSymbol x:Key="MySmallMarkerSymbol">
<esri:SimpleMarkerSymbol.ControlTemplate>
<ControlTemplate>
<StackPanel>
<Ellipse Width="50" Height="50" Fill="Red"/>
<TextBlock Text="{Binding Attributes[myDt]}"/>
</StackPanel>
</ControlTemplate>
</esri:SimpleMarkerSymbol.ControlTemplate>
</esri:SimpleMarkerSymbol>
<!--<esri:SimpleMarkerSymbol x:Key="MyMediumMarkerSymbol" Color="#FFFCEC01" Size="8" Style="Circle" />
<esri:SimpleMarkerSymbol x:Key="MyLargeMarkerSymbol" Color="#FFF60D0B" Size="12" Style="Circle" />-->
<MY:timeStrConverter x:Key="timeStrConvert"/>
</Grid.Resources>
<esri:Map x:Name="MyMap" WrapAround="True"
TimeExtent="{Binding ElementName=eventGL, Path=Value}">
<esri:ArcGISTiledMapServiceLayer ID="BaseLayer"
Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer" />
<esri:GraphicsLayer x:Name="eventGL">
<esri:GraphicsLayer.MapTip>
<Border Height="80" Background="White">
<StackPanel>
<TextBlock>�?�?�?ק�?</TextBlock>
<Rectangle Width="20" Height="20" Fill="Blue"/>
<TextBlock Text="{Binding Attributes[myDt], Converter={StaticResource timeStrConvert}}" Foreground="Black"/>
</StackPanel>
</Border>
</esri:GraphicsLayer.MapTip>
</esri:GraphicsLayer>
</esri:Map>
<Button x:Name="btnGo" Width="100" Height="20" VerticalAlignment="Top" Click="btnGo_Click" >Go</Button>
<esri:TimeSlider Name="testTS" Height="20" VerticalAlignment="Bottom" TimeMode="TimeInstant" Value="{Binding ElementName=eventGL, Path=TimeExtent}"/>
<Grid>
<!--<Rectangle Fill="Transparent" RadiusX="2" RadiusY="2" Margin="0,223,287,5">
</Rectangle>-->
<!--<StackPanel Margin="5">
<TextBlock Text="{Binding Start.Year}" FontSize="12" />
<TextBlock Text="->" FontSize="12" />
<TextBlock Text="{Binding End.Year}" FontSize="12" />
</StackPanel>-->
<!--<esri:TimeSlider x:Name="MyTimeSlider" Height="20" TimeMode="TimeExtent" MinimumValue="{Binding ElementName=MyMap, Path=g, Mode=OneWay}" MaximumValue="{Binding ElementName=MyMap, Path=g, Mode=OneWay}" Value="{Binding ElementName=MyMap, Path=g, Mode=OneWay}" Margin="0,0,265,291"></esri:TimeSlider>-->
<!--<esri:TimeSlider x:Name="MyTimeSlider" Height="20" TimeMode="TimeExtent" MinimumValue="{Binding ElementName=MyMap, Path=Layers[EarthquakesLayer].TimeExtent.Start, Mode=OneWay}" MaximumValue="{Binding ElementName=MyMap, Path=Layers[EarthquakesLayer].TimeExtent.End, Mode=OneWay}" Value="{Binding ElementName=MyMap, Path=Layers[EarthquakesLayer].TimeExtent, Mode=OneWay}" Margin="0,0,265,291"></esri:TimeSlider>-->
</Grid>
</Grid>
</Window>
using System;
using System.Linq;
using System.Text;
public class timeStrConverter : IValueConverter
public object Convert(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
DateTime dt;
if(DateTime.TryParse(value.ToString(), out dt))
return dt.ToShortDateString();
return null;
public object ConvertBack(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
throw new NotImplementedException();
