SSL and Qt 10.2.5 for iOS
4429
03-27-2015 02:16 PM
ChrisGoz
I am using the Qt Runtime SDK (10.2.5) to make an app for OS X, Android and iOS. I have also installed Esri's build of the Qt SDK for iOS (Qt540-iOS-esri.zip), and made sure the post installer is pointing to the correct qmake file.
When I try to query a secured service from my iPhone (after the map is ready), I get the dreaded "SSL handshake failed" error. The process works fine in OS X and Android, but not in iOS.
I was able to access this same service on all three platforms during the Qt 10.3 beta program.
Any ideas on how to get this working again?
Snippet of code is below.
Chris
code snippet:
    Button {
        text:"Get Users"
        visible: isEverythingReady
        onClicked: {
            console.log("getting data from table");
            myTable.getTheUsers();
    GeodatabaseFeatureServiceTable {
        onQueryServiceFeaturesStatusChanged: {
            if (queryServiceFeaturesStatus === Enums.QueryFeaturesStatusCompleted) {
                try {
                    console.log("QUERY COMPLETE!!!");
                    var iterator = queryServiceFeaturesResult.iterator;
                    var featureInTable;
                    while (iterator.hasNext()) {
                        row = iterator.next();
                        console.log("field1", featureInTable.attributeValue(nameoffield1));
                        console.log("field2", featureInTable.attributeValue(nameoffield2));
                catch(err) {
                    console.log("oops", err.message, err.lineNumber);
            } else if (queryServiceFeaturesStatus === Enums.QueryFeaturesStatusErrored) {
                console.log("!!!! ERROR onQueryServiceFeaturesStatusChanged", queryServiceFeaturesError);
        function getTheUsers() {
            console.log("setting up table properties");
            var urlString = somelayerinafeatureservice;
            myTable.url = urlString;
            myTable.credentials.userName = someserfromsignin;
            myTable.credentials.password = somepwdfromsignin;
            myQuery.where = "1=1";
            myTable.queryServiceFeatures(myQuery);
    Query {
        returnGeometry: false
LucasDanzinger
Esri Frequent Contributor
The issue is an iOS specific issue that has to do with Qt's wrapping of OpenSSL. In order to workaround this, add the following inside of the ApplicationWindow -
Component.onCompleted:{
     ArcGISRuntime.identityManager.ignoreSslErrors = true;
LucasDanzinger
