Segmentation fault since macOS 11 Update
195
11-23-2020 06:18 AM
Hallo,
i'm using the Arcgis QML SDK 100.6 on MacOS with Qt 5.13.1.
Since i've updated to MacOS Big Sur (11.0.1) my Application starts up, the window where the map should be stays grey and the application terminates with a Segmentation Fault as soon as i click the window with the map.
Here is the Failure Report from macOS:
Process:               Curves [11345]
Path:                  /Users/USER/*/Curves.app/Contents/MacOS/Curves
Identifier:            fg.Curves
Version:               0
Code Type:             X86-64 (Native)
Parent Process:        Qt Creator [657]
Responsible:           Qt Creator [657]
User ID:               501
Date/Time:             2020-11-23 15:17:00.276 +0100
OS Version:            macOS 11.0.1 (20B50)
Report Version:        12
Bridge OS Version:     3.0 (14Y908)
Anonymous UUID:        93B5BB12-6E01-DC36-648F-EB4AD9B043C0
Time Awake Since Boot: 10000 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000008
Exception Note:        EXC_CORPSE_NOTIFY
Termination Signal:    Segmentation fault: 11
Termination Reason:    Namespace SIGNAL, Code 0xb
Terminating Process:   exc handler [11345]
VM Regions Near 0x8:
    __TEXT                      102d2b000-102e97000    [ 1456K] r-x/r-x SM=COW  /Users/*/Curves.app/Contents/MacOS/Curves
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   org.qt-project.QtGui          	0x00000001053a43f4 QTextDocument::firstBlock() const + 4
1   libEsriCommonQt.dylib         	0x00000001038b0607 QRTImpl::InteractionHandler::openAttributionHyperlink(QMouseEvent const&) + 439
2   libEsriCommonQt.dylib         	0x00000001038b03d0 QtPrivate::QFunctorSlotObject<QRTImpl::InteractionHandler::connectTimers()::$_1, 0, QtPrivate::List<>, void>::impl(int, QtPrivate::QSlotObjectBase*, QObject*, void**, bool*) + 336
3   org.qt-project.QtCore         	0x000000010600de4b QMetaObject::activate(QObject*, int, int, void**) + 1435
4   org.qt-project.QtCore         	0x0000000106015d52 QTimer::timerEvent(QTimerEvent*) + 98
5   org.qt-project.QtCore         	0x0000000106006916 QObject::event(QEvent*) + 102
6   org.qt-project.QtWidgets      	0x0000000104c199fd QApplicationPrivate::notify_helper(QObject*, QEvent*) + 269
7   org.qt-project.QtWidgets      	0x0000000104c1ae02 QApplication::notify(QObject*, QEvent*) + 594
8   org.qt-project.QtCore         	0x0000000105fdccc4 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 212
9   org.qt-project.QtCore         	0x000000010603639f QTimerInfoList::activateTimers() + 991
10  libqcocoa.dylib               	0x0000000106653742 QCocoaEventDispatcherPrivate::activateTimersSourceCallback(void*) + 18
11  com.apple.CoreFoundation      	0x00007fff204339fc __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
12  com.apple.CoreFoundation      	0x00007fff20433964 __CFRunLoopDoSource0 + 180
13  com.apple.CoreFoundation      	0x00007fff204336df __CFRunLoopDoSources0 + 248
14  com.apple.CoreFoundation      	0x00007fff20432111 __CFRunLoopRun + 890
15  com.apple.CoreFoundation      	0x00007fff204316be CFRunLoopRunSpecific + 563
16  com.apple.HIToolbox           	0x00007fff2869dfd0 RunCurrentEventLoopInMode + 292
17  com.apple.HIToolbox           	0x00007fff2869ddcc ReceiveNextEventCommon + 709
18  com.apple.HIToolbox           	0x00007fff2869daef _BlockUntilNextEventMatchingListInModeWithFilter + 64
19  com.apple.AppKit              	0x00007fff22c4af85 _DPSNextEvent + 883
20  com.apple.AppKit              	0x00007fff22c4974b -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1366
21  com.apple.AppKit              	0x00007fff22c3bbda -[NSApplication run] + 586
22  libqcocoa.dylib               	0x00000001066544f3 QCocoaEventDispatcher::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 2579
23  org.qt-project.QtCore         	0x0000000105fd813f QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 431
24  org.qt-project.QtCore         	0x0000000105fdd2d2 QCoreApplication::exec() + 130
25  fg.Curves                     	0x0000000102d3385d main + 1565 (main.cpp:73)
26  libdyld.dylib                 	0x00007fff20356631 start + 1
Is there a fix for this? I've reinstalled the SKD. I would prefer not to update, because then i would have to update Qt as well, which would be quite the undertaking.
Thanks for your help!
Reply
I have now found out that this is a problem with Qt 5.13: I can't get the samples to run with 5.13 and 100.6.
The only remedy i found is to update to Qt 5.15.2. The Arcgis Version does not matter.
Reply
Esri Frequent Contributor
As Big Sur was just released a few weeks ago, our previous releases have not been tested and do not list Big Sur as a supported platform. Historically, most upgrades "just worked" regardless of an official support statement from us, so it is unclear at this point if Big Sur is any different or not.
Here is the 100.6 system requirements - https://developers.arcgis.com/qt/latest/qml/guide/system-requirements-100-6.htm -- High Sierra and Mojave are the 2 supported versions of macOS.
We are currently working on finishing up our 100.10 release, and we intend to fully test and support Big Sur for that release.
Reply
