Offline Table editing qml/qt
2124
02-09-2016 08:04 AM
tanerkoka1
Can I offline editing (GeodatabaseFeatureServiceTable ) table  without shape in qt/qml ?
Thanks.
Tags (1)
tanerkoka1
Problem was solved I'm using GenerateGeodatabaseParameters layerIds property before generate offline geodatabase like below with bold text:
        Button {
            text: "Generate Geodatabase"
            enabled: false
            style: ButtonStyle {
                label: Text {
                    text: control.text
                    color: control.enabled ? "black" : "grey"
                    horizontalAlignment: Text.AlignHCenter
            onClicked: {
                generateGeodatabaseParameters.initialize(serviceInfoTask.featureServiceInfo);
                generateGeodatabaseParameters.extent = mainMap.extent;
                generateGeodatabaseParameters.layerIds=[18];  (Table id)
                generateGeodatabaseParameters.returnAttachments = false;
                statusText.text = "Starting generate geodatabase task";
                geodatabaseSyncTask.generateGeodatabase(generateGeodatabaseParameters, gdbPath);
LucasDanzinger
Esri Frequent Contributor
Yes, you should be able to do this.
tanerkoka1
Hı,
How can I do this ? Can we use same Class's like Arcgis Runtime SDK for QT examples in Local Geodatabase editing or can we use some spatial  Class's for table aditing in offline mod.
Thanks
LucasDanzinger
If your service has a mixture of spatial and non-spatial layers that are editable in it, you should be able to use the GeodatabaseSyncTask to generate a local geodatabase, similar to the Local Geodatabase Editing sample. Then, create a GeodatabaseFeatureTable from the non-spatial table, and edit just the same as a spatial table. The only difference is that you cannot edit the geometry, as the non-spatial table will not even have geometry.
tanerkoka1
Hı,
How to create a GeodatabaseFeatureTable from the non-spatial table?I only acces in FeatureLayer's in geodatabase in download not table's .Are there any code or example how do download tables without geometry?  Here is below my GeodatabaseFeatureTable and Geodatabase
    GeodatabaseFeatureTable {
        geodatabase: gdb.valid ? gdb : null
        featureServiceLayerId:18 (Table)
Geodatabase {
path: geodatabaseSyncTask.geodatabasePath
onValidChanged:
 if (valid)
var gdbtables = gdb.geodatabaseFeatureTables;
for(var i in gdbtables)
   console.log (gdbtables[i].featureServiceLayerName);
tanerkoka1
        Button {
            enabled: false
                label: Text {
                    text: control.text
            onClicked: {
