Is MapView dockable widge?
798
09-27-2019 11:05 PM
GirishchandraY
New Contributor II
Hello Team,
I have created a Dockable widget class and created map_view in it.
Its loading properly.
But when I double click to dock it out map view is coming as blank black screen.
Can you please check.
Thank you,
by Anonymous User
Not applicable
Hi there, I can reproduce what you are seeing. This should work, but it looks like a bug in our API. I suggest you log a ticket with Esri support. They can get a bug logged with your account attached to it for tracking purposes.
GirishchandraY
New Contributor II
Ok thanks.
Can you please tell me process to log Bug.
GirishchandraY
New Contributor II
#bug
by Anonymous User
Not applicable
Hi Girishchandra, here's a link to contact technical support: Esri Support Contact Support.
If you are U.S. based, contact Esri Support directly. If international, contact your Esri Distributor and log a support case with them.
GirishchandraY
New Contributor II
Thank you for contacting us with your inquiry. Your case number is #00050252.
