Is it possible to select objects by mouse on 3D scene?
691
07-04-2017 06:31 AM
AlexeyGolovizin
New Contributor II
I have a 3D scene with a few marker objects on it (like in Scenes/Symbols example).
Can I somehow select the markers by mouse?
Is it possible to somehow move them by mouse?
LucasDanzinger
Esri Frequent Contributor
Yes, you select features in the same way as you would in 2D, because the MapView and SceneView share the same base class - GeoView - GeoView QML Type | ArcGIS for Developers
If you are trying to select graphics, use identifyGraphics() method on the mouseClicked signal to get back a list of graphics. You can then select those Graphics. If you are trying to select a feature from a layer, you would instead call identifyLayer() method.
LucasDanzinger
AlexeyGolovizin
New Contributor II
Thanks, i'll try it out.
^_^
