How to add feature attribute value
4197
03-20-2015 06:04 AM
KK2014
New Contributor III
I want to create o point feature and add string value to string attribute (ex:"description") in offline status and then sync to server.In my example I can create point feature and I give value to "description" attribute and then I give parameter in addFeature( ).In online mode my new point feature geometry created but my "description" attribute value is empty.How can I record my attribute value(ex:"Hi").?My code is below:
Thanks.
// Copyright 2014 ESRI
// All rights reserved under the copyright laws of the United States
// and applicable international laws, treaties, and conventions.
// You may freely redistribute and use this sample code, with or
// without modification, provided you include the original copyright
// notice and use restrictions.
// See the Sample code usage restrictions document for further information.
import QtQuick 2.2
import QtQuick.Controls 1.2
import ArcGIS.Runtime 10.3
import ArcGIS.Extras 1.0
ApplicationWindow {
    width: 800
    height: 600
    title: "OfflineTest"
     property double scaleFactor: System.displayScaleFactor
     property int fontSize: 15 * scaleFactor
     property bool isOnline: true
     property string featuresUrl: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Sync/WildfireSync/FeatureServer"
     property string gdbPath: "~/ArcGIS/Runtime/Data/Test/offlineSample.geodatabase"
     property var selectedFeatureId: null
     Envelope {
         xMin: -13643665.582273144
         yMin: 4533030.152110769
         xMax: -13618899.985108782
         yMax: 4554203.2089457335
     Map {
         anchors {
             left: parent.left
             top: parent.top
             right: parent.right
             bottom: msgRow.top
        extent: sfExtent
         ArcGISTiledMapServiceLayer
              url: "http://services.arcgisonline.com/ArcGIS/rest/services/Canvas/World_Light_Gray_Base/MapServer"
         FeatureLayer {
             featureTable: featureServiceTable
             Component.onCompleted: {
                 renderer = onlineRenderer
         FeatureLayer {
             featureTable: GeodatabaseFeatureTable {
                 geodatabase: gdb.valid ? gdb : null
                 featureServiceLayerId: 0
             selectionColor: "cyan"
         onMouseClicked: {
             var featureJson = {
                             geometry: {
                             x: mouse.mapX,
                             y: mouse.mapY,
                             spatialReference: mouse.mapPoint.spatialReference
                                   attributes:
                                       description: "Hi"
                               var feature = offLineLayer.featureTable.addFeature(featureJson);
                                syncButton.enabled = true;
                                statusText.text = "Tap on Sync to update the Feature Service with the edits";
     SimpleRenderer {
         symbol: SimpleMarkerSymbol {
             style: Enums.SimpleMarkerSymbolStyleCircle
             color: "red"
     GeodatabaseFeatureServiceTable {
         url: featuresUrl + "/0"
     ServiceInfoTask {
         url: featuresUrl
         onFeatureServiceInfoStatusChanged: {
             if (featureServiceInfoStatus === ServiceInfoTask.FeatureServiceInfoComplete) {
                 statusText.text = "Service info received";
                 generateButton.enabled = true;
             } else if (featureServiceInfoStatus === ServiceInfoTask.featureServiceInfoError) {
                 statusText.text = "Error:" + errorString;
                 generateButton.enabled = false;
                 cancelButton.text = "Start Over";
     Feature {
     Point {
         spatialReference: mainMap.spatialReference
     Rectangle {
         anchors {
             fill: controlsColumn
             margins: -10 * scaleFactor
         color: "lightgrey"
         radius: 5 * scaleFactor
         border.color: "black"
         opacity: 0.77
     Column {
         anchors {
             left: parent.left
             top: parent.top
             margins: 20 * scaleFactor
         spacing: 7
         Button {
             text: "Generate Geodatabase"
             enabled: false
             onClicked: {
                 generateGeodatabaseParameters.initialize(serviceInfoTask.featureServiceInfo);
                 generateGeodatabaseParameters.extent = mainMap.extent;
                 generateGeodatabaseParameters.returnAttachments = true;
                 statusText.text = "Starting generate geodatabase task";
                 geodatabaseSyncTask.generateGeodatabase(generateGeodatabaseParameters, gdbPath);
                 busyIndicator.visible = true;
         Button {
             text: "Sync"
             width: generateButton.width
             enabled: false
             onClicked: {
                 enabled = false;
                 geodatabaseSyncTask.syncGeodatabase(gdb.syncGeodatabaseParameters, gdb);
                 statusText.text = "Starting sync task";
         Button {
             text: "Cancel"
             enabled: false
             onClicked: {
                 geodatabaseSyncTask.cancelJob(syncStatusInfo);
                 enabled = false;
                 text = "Cancel";
         Row {
             spacing: 10
             Text {
                 text: appWindow.isOnline ? "  Online " : "  Offline "
                 color: "black"
             Switch {
                checked: appWindow.isOnline
                 enabled: false
                 onCheckedChanged: {
                     appWindow.isOnline = checked;
                     if (checked === true && Enums.GenerateStatusCompleted)
                         statusText.text = "Switch to Offline Mode to continue editing.";
                     else if (checked === false && Enums.GenerateStatusCompleted)
                         statusText.text = "Select a feature.";
     Geodatabase {
         path: geodatabaseSyncTask.geodatabasePath
         onValidChanged: {
             if (valid) {
                 var gdbtables = gdb.geodatabaseFeatureTables;
                 for(var i in gdbtables) {
                     console.log (gdbtables.featureServiceLayerName);
     GeodatabaseSyncStatusInfo {
     GeodatabaseSyncTask {
         url: featuresUrl
         onGenerateStatusChanged: {
             statusText.text = generateStatus;
             if (generateStatus === GeodatabaseSyncTask.GenerateComplete) {
                 statusText.text = geodatabasePath;
                 cancelButton.enabled = false;
                 isOnline = false;
                 busyIndicator.visible = false;
             } else if (generateStatus === GeodatabaseSyncTask.GenerateError) {
                 statusText.text = "Error: " + generateGeodatabaseError.message + " Code= "  + generateGeodatabaseError.code.toString() + " "  + generateGeodatabaseError.details;
         onGeodatabaseSyncStatusInfoChanged: {
             if (geodatabaseSyncStatusInfo.status === Enums.GeodatabaseStatusUploadingDelta) {
                 var deltaProgress = geodatabaseSyncStatusInfo.deltaUploadProgress/1000;
                 var deltaSize = geodatabaseSyncStatusInfo.deltaSize/1000;
                 statusText.text = geodatabaseSyncStatusInfo.statusString + " " + String(deltaProgress) + " of " + String(deltaSize) + " KBs...";
             } else
                 statusText.text = geodatabaseSyncStatusInfo.statusString + " " + geodatabaseSyncStatusInfo.lastUpdatedTime.toString() + " " + geodatabaseSyncStatusInfo.jobId.toString();
             if (geodatabaseSyncStatusInfo.status !== GeodatabaseSyncStatusInfo.Cancelled)
                 cancelButton.enabled = true;
             syncStatusInfo.json = geodatabaseSyncStatusInfo.json;
         onSyncStatusChanged: {
             featureServiceTable.applyFeatureEdits();
             featureServiceTable.refreshFeatures();
             if (syncStatus === GeodatabaseSyncTask.SyncComplete) {
                 syncButton.enabled = false;
                 statusText.text = "Sync completed."
                 switchToggle.enabled = true;
                 var errorString = "";
                 for (var j = 0; j < syncErrors.featureEditErrors.length; j++) {
                     var error = syncErrors.featureEditErrors;
                     errorString += "\nLayer Id: " + error.layerId + "\nObject Id: " + error.objectId + "\nGlobal Id: " + error.globalId + "\nEdit operation: " + error.editOperationString + "\nError: " + error.error.description;
             if (syncStatus === GeodatabaseSyncTask.SyncError)
                 statusText.text = "Error: " + syncGeodatabaseError.message + " Code= "  + syncGeodatabaseError.code.toString() + " "  + syncGeodatabaseError.details;
     GenerateGeodatabaseParameters {
     Rectangle {
         anchors {
             fill: msgRow
             leftMargin: -10 * scaleFactor
         color: "lightgrey"
         opacity: 0.77
     Row {
         anchors {
             bottom: parent.bottom
             left: parent.left
             leftMargin: 10 * scaleFactor
             right: parent.right
         spacing: 10 * scaleFactor
         BusyIndicator {
             anchors.verticalCenter: parent.verticalCenter
             enabled: false
             visible: enabled
             height: (parent.height * 0.5) * scaleFactor
             width: height * scaleFactor
         Text {
             anchors.bottom: parent.bottom
             width: parent.width
             wrapMode: Text.WordWrap
             font.pixelSize: fontSize
     Rectangle {
         anchors.fill: parent
         color: "transparent"
         border {
             width: 0.5 * scaleFactor
             color: "black"
         statusText.text = "Getting service info";
         serviceInfoTask.fetchFeatureServiceInfo();
JeanneTrieu
HI KK,
This is how you will need to change your code to make it work with the latest example:
var featureJson = {
                "attributes" :
                    "description": "hi"
                "geometry": {
                    "x": mouse.mapX,
                    "y": mouse.mapY,
                    "spatialReference": {
                        "wkid": mainMap.spatialReference.wkid
Regards,
Jen Trieu | Product Eng.
EricBader
Occasional Contributor III
KK,
First, I would suggest first that you try your code with 10.2.5, which has now been released.
I was able to refactor the code you shared and it seemed to work ok.
Let us know! Thanks
KK2014
New Contributor III
Solved the problem after converted to 10.2.5.
JeanneTrieu
HI KK,
var featureJson = {
                "attributes" :
                    "description": "hi"
                "geometry": {
                    "x": mouse.mapX,
                    "y": mouse.mapY,
Regards,
