undefined references of libEsriRuntimeQt.so
3383
12-10-2015 01:21 AM
MaximilianSchönenberg
I installed the ArcGIS Qt SDK in my Ubuntu 14.04.3 LTS virtual machine and now I'm trying to compile the ArcGIS template project. I already fixed the problem with the libc++.so.1 (see Error when compiling simple program ).
But there are still some errors (check screenshot). I tried the solution of Drew Dowling​ in sample project not compliing, map.h not found :
sudo apt-get install mesa-common-dev freeglut3 freeglut3-dev libglu1-mesa libglu1-mesa-dev libglui-dev binutils-gold packaging-dev build-essential
The errors are still there. I have no idea how to fix these errors. Please help me!
Thanks in advance! Please feel free to contact me if you need any further information.
Best regards,
Maximilian
LucasDanzinger
Esri Frequent Contributor
Hi Maximilian,
What happens if you remove "-lGL" from the LIBS? Also, what happens if you add the Qt framework's "lib" folder to LD_LIBRARY_PATH within Qt Creator?
Luke
Hi Luke,
sorry for that late answer.
It didn't worked for me. I switched now to a real machine and installed ubuntu 14.04.3 LTS and did the same steps as before (didn't need to fix the problem libc++.so.1). Now it works without a problem.
I know this isn't the solution for the problem, but now I can start my development with a working environment.
Thanks for your help!
Best regards,
Maximilian
