Hi!
I tried to update from 100.6 to 100.7
While linking the executables i got an undefined reference:
lib64/libEsriCommonQt.so: undefined reference to `operator delete(void*, unsigned long)@Qt_5'
I´m using
I tried to compile with a) -std=gnu++11 and b) -std=gnu++14, but no difference.
Which Qt did you use on Suse? The one of the operating system (suse) or did you compile Qt on your own?
Can you provide more information?
Thanks in advance!!!
Norbert
I am attaching the workaround library in this post. Also in my ArcGIS project at the very top of the library includes, I have included this library as follows:
LIBS += -L/home/fatma/Downloads/arcgisqthack/2020-11-09_ArcGISQt5Hack/ArcGISQt5Hack \
-lArcGISQt5Hack \
Oh Great, Thank you very much. I can build a lib from this CMakeList and work on my machine.
Aek
Hi @NorbertThoden , I have used the cmake version did not create a pro file. I might have made some changes in cmake file.
Hi Fatma!
Can you share your CMakeLists.txt creating your ArcGisHack-Lib with us?
Thx in advance!
