Reading ShapeFiles and converting to CIM xml format using Qt SDK API
1539
07-28-2021 09:57 PM
VikasGanesh
New Contributor II
Hi Team,
I am new to ArcGIS, I have few shapefiles now my task is to read the shapefiles contents and convert it to xml file (CIM format). I don't want to display this shapefiles in UI, I just need to read the contents of the shapefiles.  I am basically from C++ background, hence I prefer to use ArcGIS Runtime API  for Qt.
1. Can I able to read the shapefiles using ArcGIS Runtime API  for Qt ?
2. Is it possible to provide some hints or code snippets or API reference to achieve this task.
Any support in this regard is very helpful...
JamesBallard1
Hi @VikasGanesh ,
I think some of this may be doable with the Runtime, but the workflow sounds better suited to ArcGIS Pro utilizing the export tools.
https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/export-data.htm
However, if you need a Runtime solution, you can use ShapefileFeatureTable class, and that will give you access to all the features in the Shapefile feature table.
https://developers.arcgis.com/qt/cpp/api-reference/esri-arcgisruntime-shapefilefeaturetable.html
Once it's loaded you can use the inherited methods from FeatureTable, like queryFeatures to find all features, read their info and write them out (somehow) directly to xml.
https://developers.arcgis.com/qt/cpp/api-reference/esri-arcgisruntime-featuretable.html#queryFeature...
When using queryFeatures, you can provide "1=1" as your whereClause to query all features.
https://developers.arcgis.com/qt/cpp/api-reference/esri-arcgisruntime-queryparameters.html#setWhereC...
I think that would get you there, but I still think ArcGIS Pro would be the best option is it is better suited to data export workflows.
I hope this helps.
JamesBallard1
Hi @VikasGanesh ,
I hope this helps.
VikasGanesh
New Contributor II
Thanks JamesBallard1, this is really a very useful information for me to start...🙂
