Qml - load a tif map and use it offline, without any online base map?
3881
11
09-03-2017 04:50 AM
AnatBen_Israel
New Contributor II
Hi, I have a tif (and tfw) map that I want to be able to use offline (QML).
I have managed to load the tif as a raster layer on top of an online map, but I want to avoid it.
I I try to remove the BasemapImagery {}, the raster doesn't load...
In addition, how do I load the tfw file?
This is my code:
ApplicationWindow {
      width: 850
      height: 650
      title: "MapsProj"
      Rectangle {
           clip: true
           width: 800
           height: 600
           property real scaleFactor: System.displayScaleFactor
           property var rasterLayer: null
           property string rasterFilePath: "file:///C:/Projects/Sample/Maps/map1.tif"
           MapView {
                anchors.fill: parent
                Map {
                    BasemapImagery {}
                    RasterLayer {
                           Raster {
                                 path: ""
                    onLoadStatusChanged: {
                           if (loadStatus !== Enums.LoadStatusLoaded)
                                    return;
                            mapView.setViewpointCenterAndScale(fullExtent.center, 80000);
     Rectangle {
          visible: addButton.visible
           anchors.centerIn: addButton
           radius: 8 * rootRectangle.scaleFactor
           height: addButton.height + (16 * rootRectangle.scaleFactor)
           width: addButton.width + (16 * rootRectangle.scaleFactor)
           color: "lightgrey"
           border.color: "darkgrey"
           border.width: 2 * rootRectangle.scaleFactor
           opacity: 0.75
     Button {
           anchors {
                   bottom: parent.bottom
                   horizontalCenter: parent.horizontalCenter
                   margins: 32 * rootRectangle.scaleFactor
           text: "Add Raster"
           onClicked: {
                 rootRectangle.createAndAddRasterLayer(rootRectangle.rasterFilePath)
      function createAndAddRasterLayer(rasterUrl) {
          var newRaster = ArcGISRuntimeEnvironment.createObject("Raster", {path: rasterUrl});
          rasterLayer = ArcGISRuntimeEnvironment.createObject("RasterLayer", {raster: newRaster});
          rasterLayer.loadStatusChanged.connect(zoomToRaster);
          map.operationalLayers.clear();
          map.operationalLayers.append(rasterLayer);
     function zoomToRaster(){
        if (rasterLayer === null)
              return;
        if (rasterLayer.loadStatus !== Enums.LoadStatusLoaded)
              return;
         mapView.setViewpointCenterAndScale(rasterLayer.fullExtent.center, 80000);
LukeSmallwood
Hi Anat,
If you want to load your raster data without an online baseman a good option is to use  the raster itself as a layer for a local basemap. If you change your code to declare the raster as one of the baseLayers of a new Basemap (Basemap QML Type | ArcGIS for Developers ) it should load the map at the extent of your data.
    Map {
            Basemap {
                RasterLayer {
                    Raster {
                        path: rasterFilePath
Because "baseLayers" is a default property of Basemap, declaring a layer (in this case RasterLayer) as a child item will automatically add it to the list of base layers.
When you load a .tif file the .tfw should be automatically read for position information - assuming the names match and they are in the same directory. If your raster in your example code is shown in the correct place then I think the .tfw has been loaded successfully.
I hope that helps - any questions, let me know.
Luke
LukeSmallwood
Hi Anat,
    Map {
            Basemap {
                RasterLayer {
                    Raster {
Luke
AnatBen_Israel
New Contributor II
Hi Luke,
Thank you very much! Unfortunately, I guess I'm still missing something...
I've copied the raster layer center x,y from the initial implementation, and now my code is as follows:
            Map {
                Basemap {
                    RasterLayer {
                        Raster {
                            path: "file:///C:/Projects/Sample/Maps/map1.tif"
                        return;
                    var centerPoint = Qt.point(34.89521560479882, 32.133239999999994)
                    mapView.setViewpointCenterAndScale(centerPoint, 80000);
It looks as if something is loaded because I get the "For developer use only" label,
which is usually located on the map, but I don't see any map...
LukeSmallwood
Hi Anat,
You should be able to remove the "onLoadStatusChanged" block from your code. As the RasterLayer is the only layer in the basemap/map the app should automatically start at this extent.
You may find that the app is starting at a scale beyond the drawing scale of the raster - so try zooming in to see if it appears.
AnatBen_Israel
New Contributor II
Works perfect!! Thanks so much!
LukeSmallwood
Also, this call
is creating the incorrect type (I think its a QML Point). You should be creating an ArcGIS Point type by doing something like:
var centerPoint = GeometryEngine.project(ArcGISRuntimeEnvironment.createObject("Point", {x: 34.89521560479882, y: 32.133239999999994, spatialReference: sr})
AnatBen_Israel
New Contributor II
Thanks! this is going to save me so much time...
AnatBen_Israel
New Contributor II
Any idea why after all the above works, the panning doesn't work anymore?
even if I zoom in and I know I have more data beyond the visible window...
LukeSmallwood
Do you mean that you are unable to pan outside of the extents of the raster data-set?
AnatBen_Israel
New Contributor II
Not able to pan at all. I'm looking at a small window, smaller than my raster image.
I thought I would be able to pan, and when I get to the edges, get a blank area.
But I can't pan at all...
