Map fails to load a lokal TPK
1153
02-09-2017 09:04 AM
TerritoriumOnline
I'm not able to load a lokal TilePackage with the following code
property url dataPath: System.userHomePath + "/ArcGIS/Runtime/Data/"
        Map {
Basemap {
ArcGISTiledLayer {
                    url: dataPath + "tpk/SanFrancisco.tpk"
Is there something wrong or missing in the code above?
TerritoriumOnline
    ArcGISTiledLayer {         TileCache {             path: dataPath + "tpk/SanFrancisco.tpk"        }     }
I got it!
Nevertheless my own TPK created with ArcMap 10.3 did not work!
LucasDanzinger
Esri Frequent Contributor
Yes, this is a known issue for now. You will have to create the TileCache object.
Can you elaborate on what you mean by it did not work? Does it not load, not display, display incorrectly?
