Grey Image to RGB convertion
1099
5
06-29-2021 04:07 AM
TASL_Virendra
I'm trying to convert a grey scale image to RGB, but not able to do so over Qt SDK.
I was able to convert in ArcGIS pro as follows:
  1. .nitf->Input to STRETCH Raster function with Minmax->this give  me a stretch_raster layer.
  2. new Stretch raster layer-> changing symbology by changing color map.
  3. The resultant is shown below
 But samething I'm trying over qt code, I'm not able to do so color map rendering on raster file gives me below output, just single line.
does anyone faced similar issue and guide me. If required I can share code.
Virendra
TASL_Virendra
Thanks Lucas for reply!
we have tried that but this is one part of of Grey to RGB, 2nd part to convert Stretch image (0-255) as per user defined colour pallet is not working. if you have any similar example please share it.
Virendra
LucasDanzinger
Esri Frequent Contributor
Can you share some of your code for creating the renderer & layer?
TASL_Virendra
Hi Lucas,
Please find the code in attached file.
It is a trial project, so ignore the coding standard and stuff.
Virendra
LucasDanzinger
Your code sample reads color values from a text file. What does your `QList<QColor> colors` end up containing?
Also, did you take a look at the ColormapRenderer sample? This assigns color values to each pixel value https://github.com/Esri/arcgis-runtime-samples-qt/blob/main/ArcGISRuntimeSDKQt_CppSamples/Layers/Ras...
