Generate Geodatabase Extend Problem
1876
6
08-05-2016 11:46 AM
tanerkoka1
   We are using Arcgis Runtime SDK for Qt 10.2.6 and Qt 5.4.2 (MSVC 2013, 32 bit) Qt Creator QT\QML side .We have local editing application which edits features within an offline geodatabase and sync back to the service.We are using GeodatabaseSyncTask class's generateGeodatabase (GenerateGeodatabaseParameters parameters, string filename) method to generate geodatabase.
Can I generate geodatabese using without GenerateGeodatabaseParameters's  extent  property ? can I generate using only layerIds or layerQueries​ properties ?
I'm tried to generate witout extent propery with using only layerIds and layerQueries but when I can not generate , here is the console output below:
D/MaksMobil(30477): qrc:/qml/MapNumarataj.qml:291 (onGenerateStatusChanged): qml: Generate Error messageFailed to parse geometry from input JSONcode400
Best Regards
LucasDanzinger
Esri Frequent Contributor
extent/geometry is a required parameter from the rest api, so you will need to provide it - Create Replica - Feature Service (Operation) - ArcGIS
LucasDanzinger
tanerkoka1
Thanks Lucas,
Can we generate geodatabese only within poligon geometry not within poligon geometry envelope using with GeodatabaseSyncTask class's generateGeodatabase, Can we use    generateGeodatabaseParameters.extent=polygon; line of code , not generateGeodatabaseParameters.extent=polygon.queryEnvelope(); line of code  ?
Thanks
LucasDanzinger
I believe that should work, as it takes a Geometry - ArcGIS Runtime SDK for Qt QML API: GenerateGeodatabaseParameters Class Reference
tanerkoka1
Hi Lucas ,
I try to generate with poligon (generateGeodatabaseParameters.extent=polygon)  wich has more than one point but gives error when I generate .How can we solve this problem ?
Here is the console output below :
D/MaksMobil(21826): qrc:/qml/MapNumarataj.qml:293 (onGenerateStatusChanged): qml: Generate Error messageError downloading http://......./arcgis/rest/services/ADRES27/FeatureServer/createReplica?async=true&clientTime=1470763815637&dataFormat=sqlite&geometry=%7B%22rings%22:[[[3020466.09516246,4640153.3807131],[3020482.83722159,4640176.85367551],[3020526.18356831,4640237.62827268],[3020617.40875565,4640170.60837935],[3020608.96692701,4640162.67623181],[3020625.20794716,4640131.69018741],[3020622.89849908,4640131.04941413],[3020697.7013947,4639990.20336442],[3020718.4496007,4639951.13879008],[3020740.39523979,4639909.82314925],[3020747.81624781,4639895.80642545],[3020776.48003011,4639841.69178895],[3020797.89121854,4639801.26666006],[3020833.9130704,4639733.24342986],[3020869.70525637,4639665.66376684],[3020871.54603324,4639662.19201904],[3020880.52103087,4639645.23570479],[3020908.33480733,4639594.39883371],[3020950.42257043,4639529.47891321],[3020951.16372939,4639516.10542839],[3020948.52703761,4639475.598364
D/MaksMobil(21826): qrc:/qml/MapNumarataj.qml:293 (onGenerateStatusChanged): qml: Generate Error messageProtocol "" is unknowncode301
LucasDanzinger
Taner,
The following code works for me, so in general, it does work to have a polygon as your extent in the generate task
import QtQuick 2.3
import QtQuick.Controls 1.2
import QtQuick.Controls.Styles 1.2
import ArcGIS.Extras 1.0
import ArcGIS.Runtime 10.26
ApplicationWindow {
    width: 700
    height: width
    property double scaleFactor: System.displayScaleFactor
    property int fontSize: 15 * scaleFactor
    property bool isOnline: true
    property string featuresUrl: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Sync/WildfireSync/FeatureServer"
    property string gdbPath: "~/ArcGIS/Runtime/Data/Test/offlineSample.geodatabase"
    property var selectedFeatureId: null
    Envelope {
        xMin: -13643665.582273144
        yMin: 4533030.152110769
        xMax: -13618899.985108782
        yMax: 4554203.2089457335
        spatialReference: mainMap.spatialReference
    Polygon {
    Map {
        anchors.fill: parent
        focus: true
        ArcGISTiledMapServiceLayer {
            url: "http://services.arcgisonline.com/ArcGIS/rest/services/Canvas/World_Light_Gray_Base/MapServer"
        FeatureLayer {
            featureTable: root.isOnline ? featureServiceTable : local
            selectionColor: "cyan"
            function hitTestFeatures(x,y) {
                var tolerance = Qt.platform.os === "ios" || Qt.platform.os === "android" ? 4 : 1;
                var featureIds = offLineLayer.findFeatures(x, y, tolerance * scaleFactor, 1);
                if (featureIds.length > 0) {
                    selectedFeatureId = featureIds[0];
                    selectFeature(selectedFeatureId);
                    statusText.text = "Tap anywhere to move the feature";
        GraphicsLayer {
        onMouseClicked: {
            if (!root.isOnline) {
                if (offLineLayer.isFeatureSelected(selectedFeatureId)) {
                    var featureToEdit = offLineLayer.featureTable.feature(selectedFeatureId);
                    featureToEdit.geometry = mouse.mapPoint;
                    offLineLayer.featureTable.updateFeature(selectedFeatureId, featureToEdit);
                    offLineLayer.unselectFeature(selectedFeatureId);
                    selectedFeatureId = null;
                    syncButton.enabled = true;
                    statusText.text = "Tap on Sync to update the Feature Service with the edits";
                } else
                    offLineLayer.hitTestFeatures(mouse.x, mouse.y);
        onStatusChanged: {
            if (status === Enums.MapStatusReady) {
                samplePolygon.startPath(-7994031.11, 5092024.86);
                samplePolygon.lineTo(-7992530.05, 4952426.28);
                samplePolygon.lineTo(-7864939.95, 4951675.75);
                samplePolygon.lineTo(-7831916.63, 5069508.96);
                samplePolygon.lineTo(-7832667.16, 5166327.33);
                samplePolygon.lineTo(-7864189.42, 5233124.5);
                samplePolygon.lineTo(-7897963.27, 5071010.02);
                samplePolygon.lineTo(-7969263.62, 5131052.42);
                samplePolygon.lineTo(-8045817.68, 5119043.94);
                samplePolygon.lineTo(-8057826.16, 5045492);
                var graphicClone = polygonGraphic.clone();
                graphicClone.geometry = samplePolygon;
                graphicsLayer.addGraphic(graphicClone);
        Graphic {
            symbol: SimpleFillSymbol {
                color: Qt.rgba(0.5, 0, 0.0, 0.25)
                outline:  SimpleLineSymbol {
                    color: "red"
                    style: Enums.SimpleLineSymbolStyleSolid
                    width: 2
        GeodatabaseFeatureTable {
            geodatabase: gdb.valid ? gdb : null
            featureServiceLayerId: 0
        GeodatabaseFeatureServiceTable {
            url: featuresUrl + "/0"
        ServiceInfoTask {
            url: featuresUrl
            onFeatureServiceInfoStatusChanged: {
                if (featureServiceInfoStatus === Enums.FeatureServiceInfoStatusCompleted) {
                    statusText.text = "Service info received. Tap on the Generate Geodatabase Button";
                    generateButton.enabled = true;
                } else if (featureServiceInfoStatus === Enums.FeatureServiceInfoStatusErrored) {
                    statusText.text = "Error:" + errorString;
                    generateButton.enabled = false;
                    cancelButton.text = "Start Over";
        Feature {
        Rectangle {
            anchors {
                fill: controlsColumn
                margins: -10 * scaleFactor
            color: "lightgrey"
            radius: 5 * scaleFactor
            border.color: "black"
            opacity: 0.77
            MouseArea {
                onClicked: (mouse.accepted = true)
        Column {
            anchors {
                left: parent.left
                top: parent.top
                margins: 20 * scaleFactor
            spacing: 7
            Button {
                text: "Generate Geodatabase"
                enabled: false
                style: ButtonStyle {
                    label: Text {
                        text: control.text
                        color: control.enabled ? "black" : "grey"
                        horizontalAlignment: Text.AlignHCenter
                onClicked: {
                    generateGeodatabaseParameters.initialize(serviceInfoTask.featureServiceInfo);
                    generateGeodatabaseParameters.extent = samplePolygon;
                    generateGeodatabaseParameters.returnAttachments = false;
                    statusText.text = "Starting generate geodatabase task";
                    geodatabaseSyncTask.generateGeodatabase(generateGeodatabaseParameters, gdbPath);
            Button {
                text: "Sync"
                width: generateButton.width
                enabled: false
                style: generateButton.style
                onClicked: {
                    enabled = false;
                    geodatabaseSyncTask.syncGeodatabase(gdb.syncGeodatabaseParameters, gdb);
                    statusText.text = "Starting sync task";
            Button {
                text: "Cancel"
                enabled: false
                onClicked: {
                    geodatabaseSyncTask.cancelJob(syncStatusInfo);
                    enabled = false;
                    text = "Cancel";
            Row {
                spacing: 10
                Text {
                    text: root.isOnline ? "  Online " : "  Offline "
                    color: "black"
                Switch {
                    checked: root.isOnline
                    enabled: false
                    onCheckedChanged: {
                        root.isOnline = checked;
                        if (checked === true && Enums.GenerateStatusCompleted)
                            statusText.text = "Switch to Offline Mode to continue editing.";
                        else if (checked === false && Enums.GenerateStatusCompleted)
                            statusText.text = "Select a feature.";
        Geodatabase {
            path: geodatabaseSyncTask.geodatabasePath
            onValidChanged: {
                if (valid) {
                    var gdbtables = gdb.geodatabaseFeatureTables;
                    for(var i in gdbtables) {
                        console.log (gdbtables.featureServiceLayerName);
        GeodatabaseSyncStatusInfo {
        GeodatabaseSyncTask {
            url: featuresUrl
            onGenerateStatusChanged: {
                if (generateStatus === Enums.GenerateStatusCompleted) {
                    statusText.text = geodatabasePath;
                    cancelButton.enabled = false;
                    root.isOnline = false;
                    statusText.text = "Select a feature";
                } else if (generateStatus === GeodatabaseSyncTask.GenerateError) {
                    statusText.text = "Error: " + generateGeodatabaseError.message + " Code= "  + generateGeodatabaseError.code.toString() + " "  + generateGeodatabaseError.details;
            onGeodatabaseSyncStatusInfoChanged: {
                if (geodatabaseSyncStatusInfo.status === Enums.GeodatabaseStatusUploadingDelta) {
                    var deltaProgress = geodatabaseSyncStatusInfo.deltaUploadProgress/1000;
                    var deltaSize = geodatabaseSyncStatusInfo.deltaSize/1000;
                    statusText.text = geodatabaseSyncStatusInfo.statusString + " " + String(deltaProgress) + " of " + String(deltaSize) + " KBs...";
                } else
                    statusText.text = geodatabaseSyncStatusInfo.statusString + "...";
                if (geodatabaseSyncStatusInfo.status !== GeodatabaseSyncStatusInfo.Cancelled)
                    cancelButton.enabled = true;
                syncStatusInfo.json = geodatabaseSyncStatusInfo.json;
            onSyncStatusChanged: {
                featureServiceTable.refreshFeatures();
                if (syncStatus === Enums.SyncStatusCompleted) {
                    syncButton.enabled = false;
                    statusText.text = "Sync completed. You may continue editing the features.";
                    switchToggle.enabled = true;
                if (syncStatus === Enums.SyncStatusErrored)
                    statusText.text = "Error: " + syncGeodatabaseError.message + " Code= "  + syncGeodatabaseError.code.toString() + " "  + syncGeodatabaseError.details;
        GenerateGeodatabaseParameters {
        Rectangle {
            anchors {
                fill: statusText
            visible: statusText.text.length > 0
            color: "lightgrey"
            radius: 5
            opacity: 0.77
        Text {
            anchors {
                left: parent.left
                right: parent.right
                bottom: parent.bottom
            wrapMode: Text.WordWrap
            color: "black"
        Rectangle {
            color: "transparent"
            border {
                width: 0.5 * scaleFactor
                color: "black"
        Component.onCompleted: {
            statusText.text = "Getting service info";
            serviceInfoTask.fetchFeatureServiceInfo();
tanerkoka1
Hi Lucas ,
Thanks for example code , works fine but in my example have more then  1000 or 2000 point. Can you try to set over 1000 or 2000 point in polygon maybe there can be limitation points or request limitt in polgon when we  query during the generate geodatabas.How can I solve this urgent problem ?
Thanks
