find centroid of a polygon
1937
8
08-14-2020 03:34 AM
rsharma
i want to calculate centroid (center point ) of a polygon.
LukeSmallwood
Thanks rajni sharma‌ - I see what you are trying to do. This works for me:
        const ringJson = [[["172.4843305878348","-43.48191185124988"],["172.4877698503442","-43.48248171686965"],["172.48715361282302","-43.484065878559875"],["172.48428867831893","-43.48421950013839"],["172.4843305878348","-43.48191185124988"]]]
        var boundaryJson = {"rings":ringJson, "spatialReference":sr};
        var boundary= ArcGISRuntimeEnvironment.createObject("Polygon", {json: boundaryJson});
        console.log("boundary", boundary)
        console.log(JSON.stringify(boundary.json));
        var centroid = GeometryEngine.labelPoint(boundary);
        console.log("==========");
        console.log("centroid", centroid);
        console.log(JSON.stringify(centroid.json));
For reference, when you see "qml point sum hex number" you are printing the address of the Point object. To see the details of the point you need to either print property values or stringify the json:
LukeSmallwood
Hi rajni sharma‌ - you can use the GeometryEngine.labelPoint to give you a point that's within the polygon and near the center of gravity.
rsharma
how to use it , is their any example i could follow, because i could not found any example for it.
Should i use it like this:
var a = Point labelPoint(Polygon ring);
it gives some syntax error
LukeSmallwood
We have a number of samples that cover the use of GeometryEngine on github - for example look at this one.
For the label point call you should do something like:
var centroid = GeometryEngine.labelPoint(ring);
rsharma
hi Luke Smallwood
I tried it your way, but when i try to console the qml point it crashed my application everytime.
Actually i am trying to put a picture marker on centre of polygon.
So i need to get centre x and y coordinates
Suppose this is the JSON m passing in ring
 function createPolygon(ring) {
        // create polygon using json
         const sr = { "wkid": 4326};
         var boundaryJson = {"rings":ring,"spatialReference":sr};
         var boundary= ArcGISRuntimeEnvironment.createObject("Polygon", {"json": boundaryJson,"id":"property"});
        console.log(JSON.stringify(centroid));//Crashed my application
        return boundary;
LukeSmallwood
Hi rajni sharma‌ - I think this line is causing the problems because the returned Polygon will be null:
I think this should be:
(I'm not sure what the "id" : "property" is for here?)
rsharma
my application still crashed. but when i do not stringify it, it return qml point sum hex number
         var boundary= ArcGISRuntimeEnvironment.createObject("Polygon", {"json": boundaryJson});
        console.log((centroid));
        return boundary;
LukeSmallwood
rsharma
Thanks it worked. I was trying to stringify it, but didn't know, i have to stringify the json property of the point. Thanks a lot again
