Error.h: No such file or directory
1372
08-11-2017 06:01 AM
DarkRider
I've updated to arcGIS Qt SDK 100.1.0 on Linux (Ubuntu) and I get the following error message:
Error.h: No such file or directory in the FeatureTableListModel.h
The problem is that it is actually <error.h> in the standard gnu c library instead of <Error.h> (case sensitive). It compiles using <error.h> (i.e. when I change the include in the FeatureTableListModel.h to lower case).
Seems like a bug. Or do I have to consider something else?
LukeSmallwood
Hi, the filename does have an upper case "E" so I think that the line should actually be including like so:
#include "Error.h"
Luke
LukeSmallwood
#include "Error.h"
Luke
