Creating Polyline Feature
4670
7
03-31-2015 07:06 AM
KK2014
New Contributor III
I drawed polyline in my application but I can't create a new one in line layer.
Here is my code beolow:
Here is my consol output below:
Thanks.
KK2014
New Contributor III
Problem solved when I set symbolid value,line appeared on map.Because symbolid value was null.
   var feature = ArcGISRuntime.createObject("Feature");
feature.geometry = userPolyline;
feature.setAttributeValue("symbolid",'19');
offLineLayer.featureTable.addFeature(feature);
Thanks Lucas .
LucasDanzinger
Esri Frequent Contributor
I suggest you try something like the following:
offlineLayer.featureTable.addFeature(feature);
KK2014
New Contributor III
I changed my code like your code but polyline cannot created.Below is console output :
Thanks.
LucasDanzinger
KK-
Can you please post your project, or a snippet that reproduces the issue?
Luke
KK2014
New Contributor III
Here is the project below:
// Copyright 2015 ESRI
// All rights reserved under the copyright laws of the United States
// and applicable international laws, treaties, and conventions.
// You may freely redistribute and use this sample code, with or
// without modification, provided you include the original copyright
// notice and use restrictions.
// See the Sample code usage restrictions document for further information.
import QtQuick 2.0
import QtQuick.Dialogs 1.2
import QtQuick.Layouts 1.1
import QtQuick.Window 2.0
import ArcGIS.Runtime.Toolkit.Dialogs 1.0
import ArcGIS.Runtime.Toolkit.Controls 1.0
import QtQuick 2.3
import QtQuick.Controls 1.2
import QtQuick.Controls.Styles 1.2
import ArcGIS.Extras 1.0
import ArcGIS.Runtime 10.25
ApplicationWindow {
    width: 800
    height: 600
    title: "OfflinePolygonEditing"
    property double scaleFactor: System.displayScaleFactor
    property bool firstPoint: true
    property bool firstLinePoint: true
    property bool createPoint: false
    property bool isDone: false
    property int  polyGraphicId
    property int  lineGraphicId
    property int fontSize: 15 * scaleFactor
    property bool isOnline: true
    property string featuresUrl: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Sync/WildfireSync/FeatureServer"
    property string gdbPath: "~/ArcGIS/Runtime/Data/Test/offlineSample.geodatabase"
    property var selectedFeatureId: null
    property var xProp: null
    property var yProp: null
    Envelope
           xMin: 1930934.6938406308          //turkey
           yMin: 3850498.260784086
           xMax: 5912392.6567565575
           yMax: 5564737.105928443
       spatialReference: mainMap.spatialReference
    Map {
         anchors.fill: parent
         extent: sfExtent
         focus: true
         ArcGISTiledMapServiceLayer {
             url: "http://services.arcgisonline.com/ArcGIS/rest/services/Canvas/World_Light_Gray_Base/MapServer"
         FeatureLayer
            featureTable: appWindow.isOnline ? featureServiceTable : local
            selectionColor: "cyan"
         GraphicsLayer {
         onStatusChanged: {
             if (status === Enums.MapStatusReady) {
         onMouseClicked: {
             if (isDone)
                 return;
             if(createPoint)
               addLinePoint(mouse.mapPoint);
             else
                addPoint(mouse.mapPoint);
//END MAP
    GeodatabaseFeatureTable {
        geodatabase: gdb.valid ? gdb : null
        featureServiceLayerId: 0
    GeodatabaseFeatureServiceTable {
        url: featuresUrl + "/1"
    ServiceInfoTask {
        url: featuresUrl
        onFeatureServiceInfoStatusChanged:{
            if (featureServiceInfoStatus === Enums.FeatureServiceInfoStatusCompleted)
                statusText.text = "Servis bilgisi alındı.Çalışma Alanı çizimini yapın";
            else if (featureServiceInfoStatus === Enums.FeatureServiceInfoStatusErrored) {
                 statusText.text = "Error:";
                generateButton.enabled = false;
                cancelButton.text = "Start Over";
    Feature {
    Rectangle {
        anchors {
            fill: controlsColumn
            margins: -10 * scaleFactor
        color: "lightgrey"
        radius: 5 * scaleFactor
        border.color: "black"
        opacity: 0.77
        MouseArea {
            onClicked: (mouse.accepted = true)
    Column {
        anchors {
            left: parent.left
            top: parent.top
            margins: 20 * scaleFactor
        spacing: 7
        Row {
            spacing: 10 * scaleFactor
        Button {
            text: "Çalışma Alanı Sil"
            enabled: false
            width: generateButton.width
            style: ButtonStyle {
                label: Text {
                    text: control.text
                    color: control.enabled ? "black" : "grey"
                    horizontalAlignment: Text.AlignHCenter
            onClicked: {
                if (userPolygon.pathCount > 0)
                    userPolygon.removePath(0);
                isDone = false;
                firstPoint = true;
                graphicsLayer.removeAllGraphics();
                generateButton.enabled=false;
        Button {
            text: "Geodatabase Oluştur"
            enabled: false
                label: Text {
                    text: control.text
            onClicked: {
                generateGeodatabaseParameters.initialize(serviceInfoTask.featureServiceInfo);
                generateGeodatabaseParameters.extent = userPolygon;
                generateGeodatabaseParameters.returnAttachments = false;
                statusText.text = "Starting generate geodatabase task";
                geodatabaseSyncTask.generateGeodatabase(generateGeodatabaseParameters, gdbPath);
        Button {
            text: "Sync"
            enabled: false
            style: generateButton.style
            onClicked: {
                enabled = false;
                geodatabaseSyncTask.syncGeodatabase(gdb.syncGeodatabaseParameters, gdb);
                statusText.text = "Starting sync task";
        Button {
            text: "İptal"
            enabled: false
            onClicked: {
                geodatabaseSyncTask.cancelJob(syncStatusInfo);
                enabled = false;
                text = "İptal";
        Row {
            spacing: 10
            Text {
                text: appWindow.isOnline ? "  Online " : "  Offline "
                color: "black"
            Switch {
                checked: appWindow.isOnline
                enabled: false
                onCheckedChanged: {
                    appWindow.isOnline = checked;
                    if (checked === true && Enums.GenerateStatusCompleted)
                        statusText.text = "Switch to Offline Mode to continue editing.";
                    else if (checked === false && Enums.GenerateStatusCompleted)
                        statusText.text = "Select a feature.";
    Geodatabase {
        path: geodatabaseSyncTask.geodatabasePath
        onValidChanged: {
            if (valid) {
                var gdbtables = gdb.geodatabaseFeatureTables;
                for(var i in gdbtables) {
                    console.log (gdbtables.featureServiceLayerName);
    GeodatabaseSyncStatusInfo {
    GeodatabaseSyncTask {
        url: featuresUrl
        onGenerateStatusChanged: {
            if (generateStatus === Enums.GenerateStatusCompleted)
                statusText.text = geodatabasePath;
                cancelButton.enabled = false;
                appWindow.isOnline = false;
                statusText.text = "Feature Oluştur";
                createPoint= true;
            else if (generateStatus === GeodatabaseSyncTask.GenerateError)
                statusText.text = "Error: " + generateGeodatabaseError.message + " Code= "  + generateGeodatabaseError.code.toString() + " "  + generateGeodatabaseError.details;
        onGeodatabaseSyncStatusInfoChanged: {
            if (geodatabaseSyncStatusInfo.status === Enums.GeodatabaseStatusUploadingDelta) {
                var deltaProgress = geodatabaseSyncStatusInfo.deltaUploadProgress/1000;
                var deltaSize = geodatabaseSyncStatusInfo.deltaSize/1000;
                statusText.text = geodatabaseSyncStatusInfo.statusString + " " + String(deltaProgress) + " of " + String(deltaSize) + " KBs...";
            } else
                statusText.text = geodatabaseSyncStatusInfo.statusString + "...";
            if (geodatabaseSyncStatusInfo.status !== GeodatabaseSyncStatusInfo.Cancelled)
                cancelButton.enabled = true;
            syncStatusInfo.json = geodatabaseSyncStatusInfo.json;
        onSyncStatusChanged: {
            featureServiceTable.refreshFeatures();
            if (syncStatus === Enums.SyncStatusCompleted) {
                syncButton.enabled = false;
                statusText.text = "Sync tamamlandı.Feature editlemeye devam edebilirsin.";
                switchToggle.enabled = true;
            if (syncStatus === Enums.SyncStatusErrored)
                statusText.text = "Error: " + syncGeodatabaseError.message + " Code= "  + syncGeodatabaseError.code.toString() + " "  + syncGeodatabaseError.details;
    GenerateGeodatabaseParameters {
    Rectangle {
        anchors {
            fill: statusText
        visible: statusText.text.length > 0
        color: "lightgrey"
        radius: 5
        opacity: 0.77
    Text {
        anchors {
            left: parent.left
            right: parent.right
            bottom: parent.bottom
        wrapMode: Text.WordWrap
        color: "black"
    Component.onCompleted:
        statusText.text = "Getting service info";
        serviceInfoTask.fetchFeatureServiceInfo();
     Polygon {
     Polyline {
     Graphic {
         symbol: SimpleMarkerSymbol {
             color: "red"
             style: Enums.SimpleMarkerSymbolStyleCircle
     Graphic {
         symbol: SimpleFillSymbol {
             color: Qt.rgba(0.5, 0, 0.0, 0.25)
             outline:  SimpleLineSymbol {
                 color: "red"
                 style: Enums.SimpleLineSymbolStyleSolid
                 width: 2
     Graphic {
         symbol: SimpleLineSymbol {
             color: "blue"
             width: 5
     Graphic {
             color: "blue"
     function addPoint(mapPoint) {
         var newPoint = redPointGraphic.clone();
         newPoint.geometry = mapPoint;
         graphicsLayer.addGraphic(newPoint);
         var graphicClone = polygonGraphic.clone();
         if (firstPoint) {
             firstPoint = false;
             userPolygon.startPath(mapPoint.x, mapPoint.y);
             graphicClone.geometry = userPolygon;
             polyGraphicId = graphicsLayer.addGraphic(graphicClone);
         } else {
             userPolygon.lineTo(mapPoint.x, mapPoint.y);
             graphicsLayer.updateGraphic(polyGraphicId, graphicClone);
             if (userPolygon.pointCount > 2)
                 silButton.enabled = true
                 generateButton.enabled = true;//tener ekledi
                 statusText.text = "Geodatabase Oluştur Buttonuna basın";//eski
     function addLinePoint(mapPoint)
         var newPoint = bluePointGraphic.clone();
         var graphicClone;
        graphicClone = blueLineGraphic.clone();
        if (firstLinePoint) {
           firstLinePoint = false;
           userPolyline.startPath(mapPoint.x, mapPoint.y);
           graphicClone.geometry = userPolyline;
           lineGraphicId = graphicsLayer.addGraphic(graphicClone);
          } else {
           userPolyline.lineTo(mapPoint.x, mapPoint.y);
           graphicsLayer.updateGraphic(lineGraphicId, graphicClone);
           loadLayerColumn.visible = true;
     Rectangle {
         color: "transparent"
         border {
             width: 0.5 * scaleFactor
             color: "black"
     Rectangle {
         color: "lightgrey"
         radius: 5
         opacity: 0.77
         visible: loadLayerColumn.visible
         anchors {
             fill: loadLayerColumn
     ColumnLayout {
         anchors {
             left: parent.left
             right: parent.right
         spacing: 10
         visible: false
         Text {
             text: "Descrption özellik değerini gir"
         TextField {
             Layout.fillWidth: true
             visible:true
             text: "Özellik Değeri"
         Row {
             spacing: 10
             Button {
                 text: "Ok"
                 onClicked: {
                     messageDialog.text = "";
                     loadLayerColumn.visible = false;
                      syncButton.enabled = true;
                      statusText.text = "Feature Servise düzenlemeleri kaydetme için Sync butonuna bas";
                 MessageDialog
                     title: "Error"
                     icon: StandardIcon.Warning
                     modality: Qt.WindowModal
                     standardButtons: StandardButton.Ok
             Button {
                 text: "İptal"
                 onClicked: loadLayerColumn.visible = false
LucasDanzinger
I didn't debug the whole thing, but I think the reason you are getting this failure debug message is because your feature table is for layer id "0" in the feature service, which is a point, and you are trying to add in a polyline to that feature table. It doesn't match the correct geometry, so it is rejecting the addFeature() call. I recommend switching the GeodatabaseFeatureTable and the GeodatabaseFeatureServiceTable both be 1.
-Luke
KK2014
New Contributor III
I updated the GeodatabaseFeatureTable and the GeodatabaseFeatureServiceTable both to 1, but can't create polyline.
Thanks.
KK2014
New Contributor III
Thanks Lucas .
