create polygon through ArcGISRuntimeEnvironment.createObject
575
08-14-2020 02:58 AM
rsharma
This code have some error
kindly help: it do not plot outline with the fill symbol
function zmarkerSymbol(){
        var houtline={"style":Enums.SimpleLineSymbolStyleSolid, "color":"red","width":1.0};
    return ArcGISRuntimeEnvironment.createObject("SimpleFillSymbol",{"style":Enums.SimpleFillSymbolStyleSolid, "color":Qt.rgba(2, 2, 0, 0.4),"SimpleLineSymbol":{simpleLineSymbol:houtline}});
LukeSmallwood
I think the whole command should look something like this:
const houtline = ArcGISRuntimeEnvironment.createObject("SimpleLineSymbol", {style:Enums.SimpleLineSymbolStyleSolid, color:"red",width:1.0});
const sym = ArcGISRuntimeEnvironment.createObject("SimpleFillSymbol", {style:Enums.SimpleFillSymbolStyleSolid, color:Qt.rgba(2, 2, 0, 0.4), outline:houtline});
LukeSmallwood
Hi rajni sharma‌
I think the problem is that you have quotes around the properties you are using in the create function (e.g. styls, color, width). Take a look at the example in the API ref here
Does this work:
return ArcGISRuntimeEnvironment.createObject("SimpleFillSymbol",{style:Enums.SimpleFillSymbolStyleSolid, color:Qt.rgba(2, 2, 0, 0.4),"SimpleLineSymbol":{simpleLineSymbol:houtline}});
I also think you would need to call ArcGISRuntimeEnvironment.createObject for the "houtline" symbol you are creating.
rsharma
No it does not work, it just show filled symbol but it doesnot show outline. I tried this also, it shows only fillsymbol with no outline
var houtline = ArcGISRuntimeEnvironment.createObject("SimpleLineSymbol",{"style":Enums.SimpleLineSymbolStyleSolid, "color":"#FF0000","width":2.0});
   return ArcGISRuntimeEnvironment.createObject("SimpleFillSymbol",{style:Enums.SimpleFillSymbolStyleSolid, color:Qt.rgba(2, 2, 0, 0.4),simpleLineSymbol:houtline});
LukeSmallwood
rsharma
thanks luke, well if simply created it does not use outline. where was the problem actually
    // *** create simple boundary symbol ***//
     SimpleFillSymbol {
         style: Enums.SimpleFillSymbolStyleSolid
         color: Qt.rgba(1, 1, 0, 0.0)
         SimpleLineSymbol {
             style: Enums.SimpleLineSymbolStyleSolid
             color:"#ff7919"
             width: 2.0
