ArcGIS Runtime SDK for QT
2953
08-13-2014 12:14 AM
ElainaKoh
Is there anyone out there that can help? I am using the arcgis runtime sdk for qt. Is there a way to create and calculate a service area using the network analyst offline?
Thanks.
Elaina
LucasDanzinger
Esri Frequent Contributor
Hi Elaina,
The offline network datasets created through ArcGIS for Desktop (i.e. Runtime Content) support offline routing only at this time. To create service areas with the ArcGIS Runtime SDK for Qt, you would need to either use an online NA service (see the sample in our sample app), or if you need to work offline, you could also create a geoprocessing package and use the local server to execute the task. You can see here that the Generate Service Area tool is supported with the local server.
-Luke
LucasDanzinger
Hi Elaina,
-Luke
