address Suggestions in a QListView
427
10-29-2021 01:42 PM
ArtX
this is a Qt5.15 question + Runtime SDK Qt 100.12.0 and C++ code (not QML)
well...
I Try to use the address Suggestions in a QListView, populated directly from the SuggestListModel.
but I see just empty lines (without text) even though i see the coming rows in the QListView.
I also confirmed the model is working as expected, receiving the relative suggestions using the following code ...
    QList<Esri::ArcGISRuntime::SuggestResult> lst = m_suggestListModel->suggestResults();
qDebug() << lst.at(0).label();
qDebug() << lst.at(1).label();
// indeed i see the comming suggestions
this is the code i use:
SuggestParameters suggestParams;
suggestParams.setCategories(QStringList {"Address"});
suggestParams.setMaxResults(5);
m_locatorTask->suggestions()->setSuggestParameters(suggestParams);
m_suggestListModel = m_locatorTask->suggestions();
m_listview->setModel( m_suggestListModel );
m_suggestListModel->setSearchText(text);
any clue ?
thank you!
by Anonymous User
Not applicable
Hi Art,
SuggestListModel doesn't automatically populate the DisplayRole, which is the default role for rendering text in a QListView: https://doc.qt.io/qt-5/qt.html#ItemDataRole-enum
You can write either a custom delegate to render for custom roles, or write a proxy model that can massage one of the SuggestListModel's custom roles into a DisplayRole. Here's an example in the Qt tutorials where a similar approach is taken with the DecorationRole: https://github.com/Esri/arcgis-runtime-samples-qt/blob/main/ArcGISRuntimeSDKQt_CppSamples_Widgets/Di...
by Anonymous User
Not applicable
Hi Art,
ArtX
oh! thank you for the explanation.
it really explains the why.
I already did another approach
subclassing the QAbstractListModel for using it with a QListView;
i'm not sure if this is the fastest way. (maybe not)
m_suggest = new QListView;
m_suggest->setModel(&m_ListModel);
connect(m_suggestListModel, &SuggestListModel::suggestCompleted, this, &ArcGisMap::suggestResults);
void ArcGisMap::suggestResults()
   m_ListModel.list = m_suggestListModel->suggestResults(); /// (copy)
   m_ListModel.refresh();
class StringListModel : public QAbstractListModel
Q_OBJECT
public:
   StringListModel(QObject *parent = nullptr)
   : QAbstractListModel(parent) {}
int rowCount(const QModelIndex &parent) const override
   return list.count();
QVariant data(const QModelIndex &index, int role) const override
   if (!index.isValid())
   return QVariant();
   if (index.row() >= list.size())
   return QVariant();
   if (role == Qt::DisplayRole)
      return list.at(index.row()).label();
   else
      return QVariant();
void refresh()
   emit dataChanged(index(0), index(0));
QList<Esri::ArcGISRuntime::SuggestResult> list;
