Adding wms dynamic map service layer in QT/QML
5295
8
04-22-2015 07:05 AM
KK2014
I want to add wms service layer in map but caused error in layer create.I have give also correct user and password. How can I solve this problem? error is below :
ArcGIS.Runtime.Layer: void __cdecl QmlLayer::onLayerCreateError(const class QString &) QmlWmsDynamicMapServiceLayer "" "Authentication required."
ThomasDunn
KK 2014,
Can you please send along the section of code you used for connecting to and authenticating with this service? Also, let us know which platform you are testing on. Thanks.
-- TAD
P.S. I probably don't need to mention this, but please obfuscate any credential information that may appear in your code.
KK2014
Here is my code below:
// Copyright 2015 ESRI
// All rights reserved under the copyright laws of the United States
// and applicable international laws, treaties, and conventions.
// You may freely redistribute and use this sample code, with or
// without modification, provided you include the original copyright
// notice and use restrictions.
// See the Sample code usage restrictions document for further information.
import QtQuick 2.0
import QtQuick.Controls 1.2
import QtQuick.Controls.Styles 1.2
import QtQuick.Dialogs 1.2
import QtQuick.Layouts 1.1
import QtQuick.Window 2.0
import ArcGIS.Extras 1.0
import ArcGIS.Runtime 10.25
import ArcGIS.Runtime.Toolkit.Dialogs 1.0
ApplicationWindow {
    width: 800
    height: 600
    title: "IslemMWC"
    property double scaleFactor: System.displayScaleFactor
    property var serviceLayer
    Map {
        anchors.fill: parent
        focus: true
        ArcGISTiledMapServiceLayer {
            url: "http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"
    Rectangle {
        anchors {
            fill: controlsColumn
            margins: -10 * scaleFactor
        color: "lightgrey"
        radius: 5
        border.color: "black"
        opacity: 0.77
    Column {
        anchors {
            left: parent.left
            top: parent.top
            margins: 20 * scaleFactor
        spacing: 10
        Button {
            text: "Load Layer Service"
            style: ButtonStyle {
                label: Text {
                    text: control.text
                    color: "black"
                    horizontalAlignment: Text.AlignHCenter
            onClicked: {
                loadLayerColumn.visible = true
        Grid {
            columns: 2
            spacing: 10
            ExclusiveGroup {
            RadioButton {
                text: qsTr("Dynamic Layer")
                exclusiveGroup: layersExclusiveGroup
                checked: true
                style: RadioButtonStyle {
                    label: Text {
                        renderType: Text.NativeRendering
                        verticalAlignment: Text.AlignVCenter
                        font.pixelSize: 14 * scaleFactor
                        color: "black"
                        text: control.text
            RadioButton {
                text: qsTr("Feature Layer")
                checked: false
                style: dynamicRadioButton.style
    Rectangle {
        color: "lightgrey"
        radius: 5
        opacity: 0.77
        visible: loadLayerColumn.visible
        anchors {
            fill: loadLayerColumn
    ColumnLayout {
        anchors {
            left: parent.left
            bottom: parent.bottom
            right: parent.right
        spacing: 10
        visible: false
        Text {
            text: "Enter the URL for the layer service:"
        TextField {
            Layout.fillWidth: true
            visible: dynamicRadioButton.checked
            text: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/SaveTheBay/MapServer"
            style: TextFieldStyle {
                textColor:"black"
        TextField {
            visible: !dynamicRadioButton.checked
            text: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/SaveTheBay/FeatureServer/0"
            style: serviceTextField.style
        Row {
            spacing: 10
            Button {
                text: "Ok"
                style: loadButton.style
                onClicked: {
                    messageDialog.text = "";
                    loadLayerColumn.visible = false;
                    if (dynamicRadioButton.checked == true)
                        serviceLayer = ArcGISRuntime.createObject("WmsDynamicMapServiceLayer");
                        serviceLayer.url = serviceTextField.text;
                    } else {
                        var featureServiceTable = ArcGISRuntime.createObject("GeodatabaseFeatureServiceTable");
                        featureServiceTable.url = featureTextField.text;
                        serviceLayer = ArcGISRuntime.createObject("FeatureLayer");
                        serviceLayer.featureTable = featureServiceTable;
                    mainMap.addLayer(serviceLayer);
                MessageDialog {
                    title: "Error"
                    icon: StandardIcon.Warning
                    modality: Qt.WindowModal
                    standardButtons: StandardButton.Ok
                Connections {
                    target: serviceLayer
                    onStatusChanged: {
                        if (serviceLayer.status === Enums.LayerStatusErrored) {
                            messageDialog.text += serviceLayer.error;
                            messageDialog.text += " \n";
                            mainMap.removeLayer(serviceLayer);
                            messageDialog.visible = signInDialog.signIn;
                            loadButton.enabled = true;
                            dynamicRadioButton.enabled = true
            Button {
                text: "Cancel"
                onClicked: loadLayerColumn.visible = false
    UserCredentialsDialog {
        property bool signIn: false
        title: qsTr("Sign In")
        username: "user1"
        password: "user1"
        onAccepted: {
            signIn = true;
            busy = false;
            signInDialog.close()
            //taner
            loadButton.enabled = false;
            dynamicRadioButton.enabled = false
        Component.onCompleted: {
            signInDialog.visible = false;
    Connections {
        target: ArcGISRuntime.identityManager
        onUserCredentialsRequired: {
            dynamicRadioButton.enabled = true;
            signInDialog.signIn = false;
            credentials = UserCredentials
            signInDialog.visible = true;
            signInDialog.contentItem.height = Math.min(signInDialog.contentItem.screenHeight, signInDialog.contentItem.scaledHeight)
            signInDialog.contentItem.width = Math.min(signInDialog.contentItem.screenWidth, signInDialog.contentItem.scaledWidth)
            if(Qt.platform.os !== "ios" && Qt.platform.os != "android") {
                signInDialog.height = Math.min(signInDialog.contentItem.screenHeight, signInDialog.contentItem.scaledHeight)
                signInDialog.width = Math.min(signInDialog.contentItem.screenWidth, signInDialog.contentItem.scaledWidth)
            // need to wait here for signInDialog to be accepted
            while (signInDialog.visible)
                System.wait(200)
            if (signInDialog.signIn){
                credentials.userName = signInDialog.username;
                credentials.password = signInDialog.password;
                dynamicRadioButton.enabled = false;
            ArcGISRuntime.identityManager.ignoreSslErrors = true;
    Rectangle {
        color: "transparent"
        border {
            width: 0.5 * scaleFactor
            color: "black"
KK2014
I solved authenticating problem. I give in credential's username, password. And give  url in WmsDynamicMapServiceLayer .
I solved authenticating problem but any layer doesn't apear in map.
Here is output  console  below :
Starting C:\Users\tkoka\Documents\build-IslemTKGM-Desktop_Qt_5_4_0_MSVC2013_OpenGL_64bit-Debug\debug\IslemTKGM.exe...
Cannot retrieve debugging output.
QML debugging is enabled. Only use this in a safe environment.
Initializing application
ArcGIS.Runtime.Plugin: void __cdecl ArcGISRuntimePlugin::registerTypes(const char *) ArcGIS.Runtime
ArcGIS.Runtime.Plugin: void __cdecl ArcGISRuntimePlugin::initializeEngine(class QQmlEngine *,const char *) ArcGIS.Runtime
ArcGIS.Runtime.Plugin: void __cdecl ArcGISRuntimePlugin::initializeLicense(void) Invalid clientId QVariant(QString, "") status 1
ArcGIS.Runtime.Plugin: void __cdecl ArcGISRuntimePlugin::initializeEngine(class QQmlEngine *,const char *) Setting global image provider QVariant(void*, 0x3bffe70)
ArcGIS.Extras.Plugin: void __cdecl ArcGISExtrasPlugin::registerTypes(const char *) ArcGIS.Extras
ArcGIS.Extras.Plugin: void __cdecl ArcGISExtrasPlugin::registerTypes(const char *) Registering Singleton Types
ArcGIS.Extras.Core: void __cdecl TkTypes::registerTypes(const char *) ArcGIS.Extras
ArcGIS.Extras.Plugin: void __cdecl ArcGISExtrasPlugin::initializeEngine(class QQmlEngine *,const char *) ArcGIS.Extras
Rendering engine : OpenGL
ArcGIS.Runtime.Map: void __cdecl QmlMap::classBegin(void)
ArcGIS.Extras.Plugin: class QObject *__cdecl ArcGISExtrasPlugin::systemProvider(class QQmlEngine *,class QJSEngine *) QObject(0x0)
ArcGIS.Extras.Core: __cdecl TkSystem::TkSystem(class QObject *) devicePixelRatio 1
ArcGIS.Extras.Core: __cdecl TkSystem::TkSystem(class QObject *) primaryScreen.physicalDotsPerInch 72.0177
ArcGIS.Extras.Core: __cdecl TkSystem::TkSystem(class QObject *) primaryScreen.logicalDotsPerInch 96
ArcGIS.Extras.Core: __cdecl TkSystem::TkSystem(class QObject *) referenceDotsPerInch 96
ArcGIS.Runtime.Plugin: class QObject *__cdecl ArcGISRuntimePlugin::arcGISRuntimeProvider(class QQmlEngine *,class QJSEngine *) QObject(0x0)
ArcGIS.Runtime.Core: __cdecl QmlIdentityManager::QmlIdentityManager(class QObject *)
QSslSocket: cannot resolve TLSv1_1_client_method
QSslSocket: cannot resolve TLSv1_2_client_method
QSslSocket: cannot resolve TLSv1_1_server_method
QSslSocket: cannot resolve TLSv1_2_server_method
QSslSocket: cannot resolve SSL_select_next_proto
QSslSocket: cannot resolve SSL_CTX_set_next_proto_select_cb
QSslSocket: cannot resolve SSL_get0_next_proto_negotiated
ArcGIS.Runtime.Map: void __cdecl QmlMap::componentComplete(void)
ArcGIS.Runtime.Map: void __cdecl QmlMap::componentComplete(void) Adding 2 declared layer(s)
int __cdecl main(int,char *[]) ApplicationWindow_QMLTYPE_51_QML_108(0x40b7b00)
LucasDanzinger
Esri Frequent Contributor
KK -
It looks like the URL you are using for your WMS Service is actually coming from an ArcGIS Dynamic Map Service (ending in "MapServer"). The WmsDynamicMapServiceLayer expects the url to a map service that has the WMS capability enabled on it. If you are using a WMS Service coming from ArcGIS Server, it should end in "WMSServer".
Luke
KK2014
Lucas,
I have wms service like http://......./...../wms? Can I use this service in Qt/QML ? İf I can use wms service how can I get layers (Can I get subleyers with  using GroupLayerBase and add to the map).
Can I change visibility  wms service layer's sublayers ?
LucasDanzinger
KK-
Please see the class API help - ArcGIS Runtime SDK for Qt (QML API): WmsDynamicMapServiceLayer
Only the URL property for QML is exposed at this point, so doing things like getting to the individual sublayers and turning them on and off will not be supported.
Luke
CeyhunYilmaz
Hi Lucas,
İ have a question for u,
i work on wms/wfs too.But wms service like Group layer (as i think ) Just KK 2014​ said mine wms layer structure below
WMS Service
-->WMS Service Name
------->WMS Service Name
------------->layer1
------------->layer2
------------->layer:layer3
All layers there in 'layer:layer3' (for show). I want to show on map layer:layer3. Even I have tried many may many tried ways i could't show it. According to your words i started QT/C++ coding instead of QT/QML. İ can see sublayers and other properties while i debugging but i cannot show them. Please help me !
İ have worked for two weeks
LucasDanzinger
We are currently looking into this, as I'm not sure how this works with this structure.
