Add graphics to a map
1226
02-06-2020 10:26 AM
ViníciusCosta
New Contributor III
Hello,
I've been looking into a javascript example that add graphics features on a map as you draw them: Add graphics to a map | ArcGIS API for JavaScript 3.31
Is it possible to do the same thing in Qt or QML? I want to draw a retangular shape by mouse drag to select multiple features at once and haven't found a similar example.
Any help is appreciated. Thanks!
Tags (3)
LucasDanzinger
Esri Frequent Contributor
You should be able to do this still. Here is some code that should get you on the right track:
import QtQuick 2.6
import QtQuick.Controls 2.2
import QtQuick.Layouts 1.3
import Esri.ArcGISRuntime 100.7
ApplicationWindow {
    width: 800
    height: 600
    title: "Untitled123"
    property bool mouseAccepted: !freePanButton.checked
    property var startPoint
    property var endPoint
    // add a mapView component
    MapView {
        anchors.fill: parent
        // set focus to enable keyboard navigation
        focus: true
        GraphicsOverlay {
            Graphic {
            SimpleRenderer {
                SimpleFillSymbol {
                    outline: SimpleLineSymbol {
                        color: "red"
                        width: 2
                    color: "transparent"
        onMousePressed: {
            mouse.accepted = mouseAccepted;
            startPoint = mouse.mapPoint;
        onMousePositionChanged: {
            endPoint = mouse.mapPoint;
            envBuilder.setCorners(startPoint, endPoint);
            graphic.geometry = envBuilder.geometry
        // add a map to the mapview
        Map {
            // add the BasemapTopographic basemap to the map
            BasemapTopographic {}
    EnvelopeBuilder {
        spatialReference: map.spatialReference
    ColumnLayout {
        RadioButton {
            checked: true
            text: qsTr("Free Pan")
        RadioButton {
            text: qsTr("Draw Rectangle")
LucasDanzinger
The JavaScript sample is showing the "SketchEditor". This is something we don't yet have in Runtime but plan on adding. We do have samples that show how to create graphics, but you'll need to do it programmatically - arcgis-runtime-samples-qt/ArcGISRuntimeSDKQt_QMLSamples/DisplayInformation/GOSymbols at master · Esr...
ViníciusCosta
New Contributor III
Thank you!
So, right now, there's no way to do it with a mouse drag?
In the geodesic operations example I've seen that a line is draw by a mouse click. Would it be possible to adapt it to draw some sort of shape and them select the features inside it?
LucasDanzinger
import QtQuick 2.6
ApplicationWindow {
    width: 800
    height: 600
    MapView {
        focus: true
        GraphicsOverlay {
            Graphic {
            SimpleRenderer {
                SimpleFillSymbol {
                        color: "red"
                        width: 2
        onMousePressed: {
        Map {
    EnvelopeBuilder {
    ColumnLayout {
        RadioButton {
            checked: true
        RadioButton {
ViníciusCosta
New Contributor III
Thank you!
I've managed to do a little prototype based on your code.
AbhijeetSatam
New Contributor III
Hi Vinicius,
I am working with arcgis 100.8 and qt 5.14.2. I am developing my application in cpp. I intend to add drag and draw feature to my application for simple shapes like a line and simple polygons like in this example: https://developers.arcgis.com/javascript/3/jssamples/graphics_add.html . I want to use purely cpp and no qml components.
Can you share details regarding how you achieved the same. It would be of great help.
