What is the pattern for accessing attributes in the .SDK via QueryFeaturesAsync?
469
09-13-2019 08:51 AM
RichardHughes2
Does the QueryFeaturesAsync method on the FeatureTable actually return attribute values?  I am just seeing it return all the information about the layer and the fields, but not the actual attribute values that I need.
I've been unable to find it in the online docs either.  I am simply needing to get the attributes from features in layers that intersect a point.  I've done this a bunch in the other api's but am new to the sdk patterns.
All my layers are offline in a MobileMapPackage and I am obtaining them from the Map since they are not all visible in the MapView.  An Identify does not work since it only returns the visible features.
What am I missing here?
RichardHughes2
So to follow up on this.
foreach(FeatureQueryResult result in queryResults)
 foreach(Feature feat in result)
 var att = feat.GetAttributeValue("OBJECTID");
 MessageBox.Show(att.ToString());
Just iterating through the FeatureQueryResult gives me access to the Feature which has methods to access the attributes.
dotMorten_esri
Esri Notable Contributor
Yup that works. You can also use the shorthand feat.Attributes["OBJECTID"]
