We have a long running process that has been setup to use the rest API from a Runtime application. Everything works fine as long as the process takes less than an hour. When it takes more the token expires and things crash. When I get the token the Token::ExpirationDate is set to 6 hours from the time it is requested. However, it expires in one hour.
I have gone into portal to change from the default time to being 10 hours just to be sure that it was not associated to this. It was set at default (-1) which from documentation should be far longer than 6 hours (from what I read it seems it should be 2 weeks).
We use IWA for our authentication, so I don't know if this is associated to IWA and if there is something specific that needs to be done because of that.
-Joe
