Support for "Unique values, many fields" symbology?
4694
9
11-23-2015 09:27 AM
KrisFoster
New Contributor III
Any indication on when / if this will be supported for creating ArcGIS Runtime Content?  Currently I'm working around this by creating multiple layers in my Mxd for the same feature class with definition queries to simulate the behavior, but it would be nice to have this symbology type supported.
AnttiKajanus1
Occasional Contributor III
Just a fast update for this. This is in the backlog for implementation on the featureservice level and up.
AnttiKajanus1
Hey Kris,
Could you send me a simple reproducer (mxd, database) with information what you are doing so I can have a look? You can link the source to GeoNet or send it directly to me akajanus@esri.com.
AnttiKajanus1
And just for reminder, that if you want to define rendering information in the client, you should be able to define UniqueValueRenderer with many fields using renderers in the API.
KrisFoster
New Contributor III
Hi Antti,
Yep, here are the reproduction steps.  Can do this with any data.
1) Create symbology based on multiple fields.
2) Choose File -> Share As -> ArcGIS Runtime Content
3) Click on the Analyze button and see that the layer symbology is not supported.
JohnSelkirk
New Contributor III
We have the same issue. +1 on this request
AnttiKajanus1
ElwynPratt1
New Contributor II
Any idea if this will be implemented? It has been over three years?
RyanSchafer1
Any update on getting this implemented at the feature service level? It has been over two years.
ThadTilton
FWIW - A (perhaps) more straightforward workaround is to concatenate all the values you wish to use into a new field and then use the new field for the unique values. This is not ideal, of course, if you have new features and/or edits coming in that require you to keep the field updated.
Some details on implementing this technique are described here: Error: Error 00085: Layer uses an unsupported renderer (Feature Service)
by Anonymous User
Not applicable
I've modified the sample code offered with the UniqueValueRenderer so that it renders on the client side based on 3 fields.
