Runtime SDK 100.6 for .Net Does not show creating feature on map
1233
07-09-2020 07:01 AM
nrcnylmz
New Contributor II
Hello everyone,
I am trying to add feature to offline geodatabase. However, the feature that I added to the table with the geometry type point does not appear on the map. but when I add a new feature to the table with a geometry type polyline, it immediately appears on the map.
featureTable.CreateFeature(); // create feature from geodatabase table
..... // set Geometry and attributes
Feature.Geometry = GeometryEngine.Project(Feature.Geometry, MapView.SpatialReference);
await featureTable.AddFeatureAsync(feature.GetArcGISFeature()); // add feature to table
feature.GetArcGISFeature().Refresh(); // refresh feature
What is wrong?
Please help!!
nrcnylmz
New Contributor II
I found the solution finally. My aim is that I want to create a feature from feature table. Table geometry type is point. I can see the previous feature geometries on the map but the geometry od my newly added is not visible on the map. Then I used the code from esri documantation. The code was about symbology. And my problem was solved.
JoeHershman
MVP Regular Contributor
Is GetArcGISFeature is an extension method, unless I am missing something in documentation.  As a first guess I would check the symbology of the new point to be sure there is a symbol being applied to the new feature.  Also you really should not need the Refresh, it does not do a redraw of the layer, the point should be visible once added
-Joe
nrcnylmz
New Contributor II
Yes, GetArcGISFeature is an extension method. It returns ArcGIS feature class object. I use createFeature() method.It uses feature table symbology, right? So,I do not adjust the symbology. I get it from the table automatically.
nrcnylmz
New Contributor II
