RelateFeature not creating relationship in offline data
877
09-24-2020 09:56 AM
JoeHershman
MVP Regular Contributor
I am trying to creating a relationship in data that is created from taking a map offline and it does not seem to have any effect.  The code takes a list of vertices for a line and creates features that should then relate back to the line
foreach (var vertexInfo in Vertices)
	var vertexFeature = (ArcGISFeature) vertexTable.CreateFeature();
	vertexFeature.Geometry = vertexInfo.MapPoint;
	if ( vertexInfo.NmeaLocation != null )
		UpdateGpsAttributes(vertexFeature, vertexInfo.NmeaLocation);
	await vertexTable.AddFeatureAsync(vertexFeature);
	Log.Debug($"Relate Feature Origin: {feature.FeatureTable.TableName}:{feature.GetAttributeValue("OBJECTID")}");
	feature.RelateFeature(vertexFeature);
	Log.Debug($"Relate Feature Destination: {vertexFeature.FeatureTable.TableName}:{vertexFeature.GetAttributeValue("OBJECTID")}");
Everything runs without error and the features are created, however, the RelateFeatures does not do anything.  If I look at the services the relationships are defined:
In Vertex Feature Service:
  "relationships" : [
      "id" : 0,
      "name" : "PipelineLine",
      "relatedTableId" : 3,
      "cardinality" : "esriRelCardinalityOneToMany",
      "role" : "esriRelRoleDestination",
      "keyField" : "PipeLineGlobalID",
      "composite" : true
In PipeLine Feature Service:
  "relationships" : [
      "id" : 0,
      "name" : "Vertices",
      "relatedTableId" : 17,
      "role" : "esriRelRoleOrigin",
      "keyField" : "GlobalID",
      "composite" : true
This is a look Vertex at the table in the offline database, as you can see the PipeLineGlobalID relationship field is left null:
The log shows that the code to do the relate is running
The relationships are created in ArcGIS Pro prior to publishing the services to AGOL.
Any reason why this relationship does not get created?
-Joe
-Joe
MichaelBranscomb
Esri Frequent Contributor
HI,
In the offline geodatabase do you see the equivalent/correct information for the layer relationships? (GDB_ServiceIItems table > ItemInfo column)
Mike
JoeHershman
Yes the relationship info is also in the replica:
PipeLine
	"currentVersion": 10.81,
	"id": 3,
	"name": "Pipeline Line",
	"type": "Feature Layer",
	"displayField": "assetgroup",
	"description": "",
	"copyrightText": "",
	"defaultVisibility": true,
	"editFieldsInfo": {
		"creationDateField": "created_date",
		"creatorField": "created_user",
		"editDateField": "last_edited_date",
		"editorField": "last_edited_user"
	"relationships": [
			"id": 0,
			"name": "Vertices",
			"relatedTableId": 17,
			"cardinality": "esriRelCardinalityOneToMany",
			"role": "esriRelRoleOrigin",
			"keyField": "GlobalID",
			"composite": true
Vertices:
	"id": 17,
	"name": "Vertices",
	"displayField": "ESRIGNSS_RECEIVER",
	"description": "",
	"editFieldsInfo": {
	"relationships": [
			"id": 0,
			"name": "PipelineLine",
			"relatedTableId": 3,
			"role": "esriRelRoleDestination",
			"keyField": "PipeLineGlobalID",
			"composite": true
-Joe
JenniferNery
Hi Joe,
I think you may be missing a `FeatureTable.UpdateFeatureAsync(feature)` call. You can also check `ArcGISFeatureTable.GetUpdatedFeatures/CountAsync()` if the related feature is included or that this edit results to `ArcGISFeatureTable.HasLocalEdits()` or `Geodatabase.HasLocalEdits()` returning true.
Jennifer
JoeHershman
Jennifer,
Thanks for the reply.  It made me realize I needed to call AddFeatureAsync after creating the relationship.  I was calling before, using UpadateFeatureAsync would have worked also but makes more sense move the AddFeature line
     // await vertexTable.AddFeatureAsync(vertexFeature); - moved below
	 // Move to after RelateFeature
-Joe
