QueryFeaturesAsync results with limited number of attributes
284
5
09-19-2019 02:29 PM
CraigStephens1
I'll frame this question using the sample code.
arcgis-runtime-samples-dotnet\src\WPF\ArcGISRuntime.WPF.Viewer\Samples\Data\FeatureLayerQuery
When doing a QueryFeaturesAsync on the feature table, the resulting feature has only 3 attributes populated (NAME, OBJECTID, STATE_NAME).
There are quite a few more fields available as shown here.  And, of course, this fails:
var abbrev = feature.Attributes["ST_ABBREV"];
How do you execute QueryFeaturesAsync and get all of the attributes returned?
Reply
JoeHershman
MVP Regular Contributor
Reply
JoeHershman
Reply
CraigStephens1
Thanks Joe!  In the end, this does make sense.  In the absence of experience or message boards, this answer is elusive in both the samples and online help.
Reply
JoeHershman
I will agree that the documentation of ArcGISFeature:LoadAsync is lacking and the sample that does exist is not giving any indication of the purpose of the method
However, and not to be rude, GeoNet is a forum for community collaboration, not sure what you mean by lack of message board.  You received a response to your question within a day and it actually relates back very closely to a previously asked and answered question.  So I think this forum served you well and achieved it's purpose.
Reply
CraigStephens1
That's not what I was trying to convey.  To put it another way... if one doesn't have the experience with Esri 100.x or access to the message boards, this would have been hard to solve on their own.
By no means was I intending a slam on the message boards.
JoeHershman
Sorry for misinterpretation, and I agree.  I think the same could be said of most any type of development.  Without a forum like Stack Overflow I would not have been able to solve a nearly infinite number of problems I had in WPF.  Documentation can only go so far, and will in most cases only address the most fundamental use case and leave it to the developer to take it the next step.
Reply
