Map seach error
467
09-13-2017 06:37 PM
YuriGvozdev
Search by map (vector * .mmpk) returns the number of objects specified in the settings, but returns the same object. For example, when searching for "Street Sadovaya" returns several objects with the same coordinates. How to make it look for different objects
dotMorten_esri
Esri Notable Contributor
Could you be a little more specific? How are you doing the search? Do you have a small sample that reproduces the problem you're seeing?
YuriGvozdev
public delegate void dlgFind(int sfF);
public event dlgFind onFind;
public async void FindObj(string fnTxt)
_i = 0;
_findOverley.Graphics.Clear();
var gm = (Esri.ArcGISRuntime.Geometry.Geometry)MyMapView.VisibleArea;
var mapCenter = MyMapView.GetCurrentViewpoint(ViewpointType.CenterAndScale).TargetGeometry as MapPoint;
var geocodeParams = new GeocodeParameters
MaxResults = 10,
PreferredSearchLocation = mapCenter,
CountryCode = "RUS",
OutputLanguage = new System.Globalization.CultureInfo("ru-RU"),
OutputSpatialReference = SpatialReferences.Wgs84
results = await locator.GeocodeAsync(fnTxt, geocodeParams);
if (results.Count == 0)
MessageBox.Show("По вашему запросу ничего не найдено!", "Ничего не найдено", MessageBoxButton.OK, MessageBoxImage.Information);
return;
onFind?.Invoke(1);
string pathStr = @"pack://application:,,,/ctlGeoViev;component/Images/places16.png";
Uri cUri = new Uri(pathStr);
PictureMarkerSymbol _ps = new PictureMarkerSymbol(cUri);
_ps.OffsetY = 12;
var seekY = results[0].InputLocation.Y;
var seekX = results[0].InputLocation.X;
Graphic gr = new Graphic(mp, _ps);
_findOverley.Graphics.Add(gr);
public async void FindObjNext()
_i++;
if (_i < results.Count)
_ps.OffsetY = 12;
var seekY = results[_i].InputLocation.Y;
var seekX = results[_i].InputLocation.X;
else
onFind?.Invoke(0);
MessageBox.Show("Поиск завершен!", "", MessageBoxButton.OK, MessageBoxImage.Information);
