Identify features also support FeatureCollectionLayer
285
12-11-2017 03:12 AM
TakahiroKAMIYA
Does IdentifyLayerAsync Method also support FeatureCollectionLayer?
https://developers.arcgis.com/net/latest/forms/guide/identify-features.htm
https://developers.arcgis.com/net/latest/ios/api-reference//html/T_Esri_ArcGISRuntime_Mapping_Featur...
The GeoElement list is empty.
var layer = MyMapView.Map.OperationalLayers[0];
var pixelTolerance = 20;
var returnPopupsOnly = true;
var maxResults = 1;
var idResults = await MyMapView.IdentifyLayerAsync(layer, e.Position, pixelTolerance, returnPopupsOnly, maxResults);
foreach (GeoElement idElement in idResults.GeoElements)
     Feature idFeature = idElement as Feature;
     //idLayer.SelectFeature(idFeature);
FeatureCollectionLayer idLayer = idResults.LayerContent as FeatureCollectionLayer;
FeatureCollectionTable tables = (idLayer.FeatureCollection.Tables).FirstOrDefault();
var fields = tables.LayerInfo.Fields;‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
dotMorten_esri
Esri Frequent Contributor
The FeatureCollectionLayer is a group layer of FeatureLayers, so instead parse in the layers inside the collection. Ie
var sublayer = ((FeatureCollectionLayer)layer).Layers[0];
var idResults = await MyMapView.IdentifyLayerAsync(sublayer, e.Position, pixelTolerance, returnPopupsOnly, maxResults);
dotMorten_esri
...actually did you look at the idResults.SublayerResults ? Come to think of it, your geoelements might just be in there.
TakahiroKAMIYA
Hello Morten,
Thank you for the information.
We were able to get elements of GeoElements from idResults.SublayerResults.
Thank you very much!
