HydrographicS52DisplayProperties being reset
2527
12-11-2014 02:20 PM
ChrisSmith10
I would like to programmatically set the HydrographicS52DisplayProperties to custom values and let the user change those values through a dialog. The problem that I am running into is that loading the first S-57 layer overwrites my changes.
This seems like a bug to me.
var HydroS52DisplayProperties = HydrographicS52DisplayProperties.Default;
HydroS52DisplayProperties.TextGroupProperties.BerthNumber = false;
HydroS52DisplayProperties.TextGroupProperties.GeographicNames = false;
// load a hydro layer into the map
var layer = new HydrographicS57Layer();
layer.DisplayName = "Sacrificial Layer";
EsriMap.Layers.Add(layer);
// after the layer is loaded the HydrographicS52DisplayProperties
// will be reset to the defaults. BerthNumber and GeographicNames
// from above will be true
I'm using Runtime .NET SDK version 10.2.4.748
AnttiKajanus1
At the moment settings get reset but you can change values after you wait layers loaded.
// wait until all layers are loaded
await MyMapView.LayersLoadedAsync();
HydrographicS52DisplayProperties.Default.ViewGroupProperties.Soundings = false; // changes
