How to work with file geodatabases ?
125
10-08-2018 01:36 AM
Hi , I am working in a complete disconnected environment. I want to create and edit features. How can I use file geodatabase with arcgis runtime app, so that i can persist data and later modify as and when required. I am unable to find any help in the documentation regarding file geodatabase ?
Thanks in advance
Reply
Esri Frequent Contributor
The preferred geodatabase in ArcGIS Runtime is the mobile geodatabase (Create an offline map—ArcGIS Runtime SDK for .NET (WPF) | ArcGIS for Developers).
File geodatabases are supported using the WPF API on Windows with ArcGIS Runtime Local Server via LocalMapService and LocalFeatureService types. For more information see:
Local Server—ArcGIS Runtime SDK for .NET (WPF) | ArcGIS for Developers
Layer types described—ArcGIS Runtime SDK for .NET (WPF) | ArcGIS for Developers
Package Map—Data Management toolbox | ArcGIS Desktop
Cheers
Mike
But , the mobile geodatabase does not support editing of features until and
unless I use feature service as per the documentation . I don't want to use
sync enabled geodatabase . How can I work in complete offline mode so that
editing is supported and data get persisted in geodatabase ?
Reply
