Geo Referenced BMP
58
Sunday
Highlighted
I'm using 100.9 runtime and found out that BMP files are not supported by Raster Layer,
Is there a simple way to open the bmp file and determine if its geo referenced?
using runtime sdk or any other way (without using external software like arcgis pro of course)
Thanks for any advice!
Reply
Highlighted
Hi Yaron
You have two different questions here.
BMP is a format that have no header or georeference info in file.
If it does not have a prj and a world file then it is have no geo reference information.
If you want to use it you must create these two files.
Second if you have local server you can use it to convert it to tiff. If the BMP have the georeference information it will be translated to the tiff.
Have Fun
Reply
Highlighted
Esri Frequent Contributor
You could try using a KML GroundOverlay
e.g. `GroundOverlay_BMP.kml` references a bitmap via relative path `BMP\bmp.bmp`:
<?xml version="1.0" encoding="utf-8"?>
<kml xmlns="http://www.opengis.net/kml/2.2">
<GroundOverlay>
<name>GroundOverlay_BMP</name>
<Icon>
<href>BMP/bmp.bmp</href>
</Icon>
<LatLonBox>
<north>20</north>
<south>0</south>
<east>20</east>
<west>0</west>
<rotation>0</rotation>
</LatLonBox>
</GroundOverlay>
</kml>
Mike
Reply
