Feature Layer Label Style
691
05-08-2017 07:28 AM
MarcTidd
I want to add street lines with labels from a geodatabase.
I have this working using a FeatureLayer and a GeodatabaseFeatureTable.  I can easily control the styling of the line but see no way to simply set the label color.
Here is the code I am using to create the feature layer.
var gdb = await Esri.ArcGISRuntime.Data.Geodatabase.OpenAsync(f);
// get the first table
var gdbFeatureTable = gdb.GeodatabaseFeatureTable(0);
// create a FeatureLayer to display the table
fl = new FeatureLayer(gdbFeatureTable);
Symbol sym = new SimpleLineSymbol(SimpleLineSymbolStyle.Solid, Color.Gray, 14);
SimpleRenderer sr = new SimpleRenderer(sym);
fl.Renderer = new SimpleRenderer(sym);
fl.LabelsEnabled = true;
This seems like such a simple thing, what am I missing?
Does anyone have any sample code?
MichaelBranscomb
Esri Frequent Contributor
Currently in v100.0 you need to setup the labels for your lines in ArcGIS Pro before creating your Mobile Map Package (or publishing a sync-enabled feature service). In the upcoming Update 1 release we plan to add some support to the API for setting label style and behavior programmatically, followed by a more extensive API in Update 2 later this year.
Cheers
Mike
MichaelBranscomb
Cheers
Mike
