Draw status changed
532
02-08-2019 09:56 AM
SaurabhGupta1
Hello,
I'm working on some offline development and showing the spinner when map draw status changed. When I do window lock and unlock my window then I see that draw status changed event happens only one time, after that it's not executing.
Here is the sample code which I am using.
private void PgeMapView_DrawStatusChanged(object sender, DrawStatusChangedEventArgs e)
try
//Update the load status information
Dispatcher.Invoke(delegate ()
// Show the activity indicator if the map is drawing
if (e.Status == DrawStatus.InProgress)
labelMessage.Visibility = System.Windows.Visibility.Visible;
labelMessage.Text = "Loading layers..";
ProgressSpinner_lyr.Visibility = System.Windows.Visibility.Visible;
ProgressSpinner_lyr.Spin = true;
ProgressSpinner_lyr.Refresh();
//MapStatusProgressBar.IsEnabled = true;
//MapStatusProgressBar.Visibility = System.Windows.Visibility.Visible;
else
labelMessage.Visibility = System.Windows.Visibility.Collapsed;
ProgressSpinner_lyr.Visibility = System.Windows.Visibility.Collapsed;
pgeMapView.DrawStatusChanged -= PgeMapView_DrawStatusChanged;
pgeMapView.DrawStatusChanged += PgeMapView_DrawStatusChanged;
catch (Exception ex)
string message = ex.Message;
SaurabhGupta1
I found the issue, this is happening when you add the feature table which does not have geometry. Now I am looking how to not add these feature tables on Map while loading GeoDatabase File.
