Does anyone have a good ModelMarkerSymbol example with a 3ds model?
3303
10
08-07-2015 04:52 AM
PhilipCollier
New Contributor II
I have been trying to use the ModelMarkerSymbol in the new 10.2.6.  So far I have not been able to get anything to display.  This is the link to the model I have been trying,
http://tf3dm.com/3d-model/mq-9-predator-7547.html
Does anyone have a good example of how to use this type of symbol with a 3ds model.  There doesn't seem to be one included in the samples.
Phil.
AnttiKajanus1
Regular Contributor II
I try to write one tomorrow if you still have issues with 3d symbols.
cheers,
Antti
AnttiKajanus1
You should be able to create it more or less like this:
Create renderer with ModelMarkerSymbol
<esri:SimpleRenderer x:Key="RedArrowModelRenderer">
    <esri:SimpleRenderer.Symbol>
         <esri:ModelMarkerSymbol Scale="1000" SourceUri=".\\Data\\RedArrow.dae"/>
    </esri:SimpleRenderer.Symbol>
    <esri:SimpleRenderer.SceneProperties>
        <esri:RendererSceneProperties HeadingExpression = "[heading]" PitchExpression="[pitch]" RollExpression="[roll]"/>
    </esri:SimpleRenderer.SceneProperties>
</esri:SimpleRenderer>
Then just define your layer to use that renderer.
PhilipCollier
New Contributor II
Annti,
Thanks for your example.  Unfortunately I am still having issues.  I have applied the renderer to a graphics overlay and tried adding a graphic.  Nothing displays.  I have replaced the modelmarkersymbol for a straight marker symbol and that displays fine.  Both 3ds and dae models have been tried.  I have a feeling its something to do with the path.  Have you tested the above example with success?
Regards
Phil.
AnttiKajanus1
Just make sure that the path is correct to the dae file. If you include that to the project, make sure that it ends to the bin folder too. If that doesn't help,could you provide me a simple reproducer from your issue?
PhilipCollier
New Contributor II
Annti,
I will post my example to you when I get home from work, its on my other laptop.
Many thanks,
Phil.
PhilipCollier
New Contributor II
Annti,
Did you manage to have a look at the example I uploaded?  I have had a little success with some models I downloaded, by ensuring the textures where in the same level as the 3ds file.  Some models, however just do not work regardless.
AnttiKajanus1
I had finally time to check it today and I can see what you are seeing. I sent it to my colleague that knows more about 3d than I do. Hopefully he can figure it out.
PhilipCollier
New Contributor II
Excellent, thanks for your assistance.
Phil.
ApurvaGoyal
New Contributor III
Hello,
My colleague Antti forwarded me your question. To display textures, you need following steps-
1) Create a folder name DHCChipmunk inside Data/Models/Chips3ds (same location where your .3DS file exists).
2) Move all jpegs to DHCChipmunk folder
3) Rename your .3ds file to same name as folder (DHCChipmunk.3ds)
You should now see the textures. The idea is that the JPEGs should reside in a folder named same as the .3ds or .dae file.
Please let me know if you have any questions.
Thanks
Apurva
