Display selectable Points at runtime
1154
05-05-2021 02:34 PM
JacobPorter
I am trying to get a Map that has selectable points that will navigate to a details page. These points are coming from a local database that can change often. The map will need to set these points at runtime. The map will also need to be offline. Any tips on what tools to use would be great. I have currently tried a map with graphics.
MikeBrownNCDOT
New Contributor II
ArcGIS might be overkill for what you are looking to do. It is more about working with points stored in a service or feature layer. You can manually add all the points at runtime as a graphics overlay, as you mentioned. This would be the same method used by pretty much any mapping library you'll use (I've used GMaps.NET for this before).
I'm sure you are aware, but here is the tutorial for the graphics overlay: Add a point, line, and polygon | ArcGIS Runtime API for .NET | ArcGIS for Developers
You would just hand your MapViewModel a list of the points & metadata from your database at runtime and loop through, adding one point at a time. Keep in mind this isn't live data - you would refresh this cache through another bulk query & data processing.
JacobPorter
Thanks for the help. I am currently just doing it with Graphics. A couple of other parts of my app are it is a Xamarin Forms app and it needs to go offline and still have the maps with pins and also the ability to navigate. Not sure if Gmaps.net supports Xamarin, but will also give it a try.
MichaelBranscomb
Esri Frequent Contributor
The approach with the best support for this scenario would be using a feature service and one of the offline map workflows (as mentioned in an earlier reply): https://developers.arcgis.com/net/offline-maps-scenes-and-data/.
A GraphicsOverlay might fit your needs, but you could also take a look at FeatureCollections which provide ToJson/FromJson methods for saving (they also support saving as portal items): https://developers.arcgis.com/net/wpf/api-reference/html/T_Esri_ArcGISRuntime_Data_FeatureCollection....
For a sample see https://developers.arcgis.com/net/wpf/sample-code/feature-collection-layer/.
DvB
New Contributor II
I know this might be to old for you now but in case others have a similar need.
A simple way to go about this using just Graphics and GraphicsOverlays could be for you to load the points from the database, create a MapPoint for each one, and a Graphic using each MapPoint as its geometry. You can then put them into a GraphicOverlay of your choice, and use the MapView.GeoViewTapped/GeoViewDoubleTapped events to capture when a user clicks on those Graphics/Points. You could then MapView.IdentifyGraphicsOverlaysAsync(...) or just have a collection of the same points that you use to reference the latlon and if the position you get from the GeoViewTapped events is in there, go to the detail's page related to that point.
DvB
New Contributor II
Also, you could put in each Graphic a KeyValuePair<string, object> that has some identifying information you can use to navigate to the details page. So after identifying the graphics, you can check if they have any keyvaluepair that matches what you want, and then navigate to your page, however your application handles that.
