Cannot create replicas from ArcGIS Pro created services
418
06-26-2017 06:18 AM
MVP Regular Contributor
I am curious if anyone else sees the same issue.  I am unable to generate a replica through the API for any service that is created in ArcGIS Pro.  These are feature services which use referenced data (not hosted).  The database is archive enabled non-versioned data following the esri suggested approach.
I create the service in Pro, go to Server Manager to enable replication and then trying to create the replica via the API fails. Always!.  I have seen this behavior on two different AGS/Portal servers and have tried using Pro 2.0.
If I use the same exact data and the exact same code but create the Feature Service in ArcMap everything works fine. Replica created and downloaded as expected.
I cannot believe this would not have been tested during development, so would love some insight into why I see this issue
Thanks
-Joe
Reply
