Authenticating to internal proxy (407)
4344
06-10-2015 04:11 PM
JohnDye
Occasional Contributor III
So, this is literally my first day writing a single line of C# and working with the .NET SDK. The Developer documentation has been really good thus far and I've been able to understand everything pretty well.
Unfortunately, when I got towards the end of the third tutorial, I ran into a problem - my corporate proxy.
Since this is my first day working with C#, I'm not sure how to build a function to use IWA to authenticate to our internal proxy.
Any help or guidance is greatly appreciated.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Data;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Imaging;
using System.Windows.Navigation;
using System.Windows.Shapes;
using Esri.ArcGISRuntime.Controls;
using Esri.ArcGISRuntime.Portal;
using Esri.ArcGISRuntime.WebMap;
namespace FirstApp
    /// <summary>
    /// Interaction logic for MainWindow.xaml
    /// </summary>
    public partial class MainWindow : Window
        public MainWindow()
            InitializeComponent();
        private ArcGISPortal arcGISOnline;
        private ArcGISPortalItem selectedPortalItem;
        // changes the basemap layer
        private void baseMap_SelectionChanged(object sender, SelectionChangedEventArgs e)
            var combo = sender as ComboBox;
            var sel = combo.SelectedItem as ComboBoxItem;
            if (sel.Tag == null) { return; }
            //Find and remove the current basemap layer from the map
            if (mainMap == null) { return; }
            var oldBasemap = mainMap.Layers["BaseMap"];
            mainMap.Layers.Remove(oldBasemap);
            //Create a new basemap layer
            var newBaseMap = new Esri.ArcGISRuntime.Layers.ArcGISTiledMapServiceLayer();
            //Set the ServiceUri with the url defined for the ComboboxItem's Tag
            newBaseMap.ServiceUri = sel.Tag.ToString();
            //Give the layer an ID so it an still be found with the code above
            newBaseMap.ID = "BaseMap";
            //Insert the new basemap layer as the first (bottom) layer in the map
            mainMap.Layers.Insert(0, newBaseMap);
        // searches the portal for content
        private async void SearchButton_Click(object sender, RoutedEventArgs e)
            try
                if (this.arcGISOnline == null)
                    // create the uri for the portal
                    var portalUri = new Uri("https://gis.kdc.capitalone.com/portal/sharing/rest");
                    // create the portal
                    this.arcGISOnline = await ArcGISPortal.CreateAsync(portalUri);
                // create a variable to store search results
                IEnumerable<ArcGISPortalItem> results = null;
                if (this.ItemTypeCombobox.SelectedValue.ToString() == "BaseMap")
                    // basemap search returns web maps that contain the basemap layer
                    var basemapSearch = await this.arcGISOnline.ArcGISPortalInfo.SearchBasemapGalleryAsync();
                    results = basemapSearch.Results;
                else
                    // get the search term provided in the UI
                    var searchTerm = this.SearchTextBox.Text.Trim();
                    var searchItem = this.ItemTypeCombobox.SelectedValue.ToString();
                    // build a query that searches for the specified type
                    // ('web mapping application' is excluded from the search since 'web map' will match those item types too)
                    var queryString = string.Format("\"{0}\" type:(\"{1}\" NOT \"web mapping application\")", searchTerm, searchItem);
                    var searchParameters = new SearchParameters()
                        QueryString = queryString,
                        SortField = "avgrating",
                        SortOrder = QuerySortOrder.Descending,
                        Limit = 10
                    // execute the search
                    var itemSearch = await this.arcGISOnline.SearchItemsAsync(searchParameters);
                    results = itemSearch.Results;
                // show the results in the list box
                this.ResultListBox.ItemsSource = results;
            catch (Exception ex)
                MessageBox.Show(ex.Message, "Error searching Atlas");
        // resets the UI controls to keep them in sync with the currently selected portal item in the ResultsListBox
        private void ResetUI()
            // clear UI controls
            this.SnippetTextBlock.Text = "";
            this.ThumbnailImage.Source = null;
            this.ShowMapButton.IsEnabled = false;
        private void ResultSelectionChanged(object sender, SelectionChangedEventArgs e)
            this.ResetUI();
            // store the currently selected portal item
            this.selectedPortalItem = this.ResultListBox.SelectedItem as ArcGISPortalItem;
            if (this.selectedPortalItem == null) { return; }
            // show the portal item snippet (brief description) in the UI
            if (!string.IsNullOrEmpty(this.selectedPortalItem.Snippet))
                this.SnippetTextBlock.Text = this.selectedPortalItem.Snippet;
            // show a thumnail for the selected portal item (if there is one)
            if (this.selectedPortalItem.ThumbnailUri != null)
                var src = new BitmapImage(this.selectedPortalItem.ThumbnailUri);
                this.ThumbnailImage.Source = src;
            // enable the show map button when a web map portal item is chosen
            this.ShowMapButton.IsEnabled = (this.selectedPortalItem.Type == ItemType.WebMap);
        private async void ShowMapButton_Click(object sender, RoutedEventArgs e)
            // create a web map from the selected portal item
            var webMap = await WebMap.FromPortalItemAsync(this.selectedPortalItem);
            // load the web map into a web map view model
            var webMapVM = await WebMapViewModel.LoadAsync(webMap, this.arcGISOnline);
            // show the web map view model's map in the page's map view control
            this.mainMapView.Map = webMapVM.Map;
JohnDye
Got it!
If your internal proxy is blocking a request you are sending outside the domain and you're getting a 407 error -  provided your internal proxy uses IWA, you can simply update your App.config XML to with the <system.net> tag and set the <defaultProxy useDefaultCredentials> property to True.
<?xml version="1.0" encoding="utf-8" ?>
<configuration>
    <startup>
        <supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.5" />
    </startup>
  <system.net>
    <defaultProxy useDefaultCredentials="True" />
  </system.net>
</configuration>
JohnDye
Got it!
<configuration>
    <startup>
    </startup>
  <system.net>
  </system.net>
</configuration>
Mannus_Etten
New Contributor III
yeah this only works in .net framework and not in .net5
CEO the Right Direction BV/Portal Genius
