WPF TableOfContents now expanded by default (100.7.1)
398
04-16-2020 10:50 AM
JoeHershman
MVP Regular Contributor
In previous versions of the TableOfContents control the treeview was collapsed by default.  Now in 100.7.1 it is expanded by default.  We have a large number of layers and this is not acceptable to the users.
Current default:
I tried to see if I could close them when the TableOfContents is loaded by setting IsExpanded on the item to false, but this did not take
foreach (var item in TableOfContents.ItemsSource)
	if ( item is TocItem tocItem )
		tocItem.IsExpanded = false;
How can I get these to be collapsed when the TableOfContents initially
Morten Nielsen
-Joe
-Joe
JoeHershman
I did find a solution that works by setting the IsExpanded when the item is added to the collection.  The following was added in the views code behind constructor
var collection = TableOfContents.ItemsSource as INotifyCollectionChanged;
if ( collection == null ) return;
collection.CollectionChanged += (sender, args) =>
	if ( args.NewItems == null ) return;
	foreach (var item in args.NewItems)
-Joe
JoeHershman
-Joe
