What is this ResponsiveFormContainer you use in your Xamarin samlples?
699
06-04-2020 02:11 PM
JayBowman
I'm writing a Xamarin navigation application and looking at your sample code you have an xmlns of  xmlns:resources="clr-namespace:Forms.Resources;assembly=ArcGISRuntime" and you have a component of ResponsiveFormContainer. What Ersi nuget package contains this? I can't find any documentation on it. I have created a navigation page very simular to your sample Xamarin.Forms NavigateRoute. I'm using the RouteTrackerDisplayLocationDataSource and the SimulatedLocationDataSource. I create the route and display it on my map fine. But when i start the navigation. I get the InputLocationChanged  event on the RouteTrackerDisplayLocationDataSource . But the map never moves.
I just got this message
Esri.ArcGISRuntime.ArcGISRuntimeException
Message=Attempt to use an unlicensed extension: ArcGIS Runtime is not licensed to use Navigation.
I have my license set in the Xamarin app class right before
 ArcGISRuntimeEnvironment.Initialize();
NathanCastle1
The responsive form container is used to position content appropriately based on device type. It is a part of the sample viewer, and not a component of the Runtime API. Implementation is at arcgis-runtime-samples-dotnet/ResponsiveFormContainer.xaml at master · Esri/arcgis-runtime-samples-d...
Regarding navigation problems, there may be a licensing issue here. Does it work if you don't set the license and leave Runtime in the development mode?
NathanCastle1
Also want to add that navigation requires the Basic (or greater) license level.
