VTPK Setting maximum extent after switching basemap to portal item.
326
04-14-2022 05:38 PM
AaronMorrisett
New Contributor II
I am creating a offline basemap using the ExportTileCacheTask and when I load that basemap it locks the maximum extent of the mapview to the size of the created basemap.  However my problem is when I switch to map from the arcgis portal that covers the whole earth the highest I can zoom out is stuck to what was set to when it loaded in the *.vtpk file.  I have tried to browse around for some properties to adjust this but haven't had any luck yet.
      Aaron
dotMorten_esri
Esri Notable Contributor
Update 14 (out soon) will allow you to override the automatically set max extent initialized at startup.
dotMorten_esri
dotMorten_esri
Just following up after U14 shipped this week. Feel free to try this version and set the MaxExtent property on the Map.
https://developers.arcgis.com/net/api-reference/api/netwin/Esri.ArcGISRuntime/Esri.ArcGISRuntime.Map...
