View tile package (.tpk) at all levels of detail.
4356
9
09-05-2017 09:10 AM
NicholasVolpe
We are using a tile package as a base map for offline use. However, to keep the tile package file size as small as possible, we do not download all the levels of detail. But the tile package will disappear when zoomed in 'beyond' or 'beneath' it.
Is there a way to keep the Tile Package displayed even if the map is zoomed in to lower levels of details, and there is not a matching level of detail in the tile package. I know the image will be disported and pixelated. But it would be better than an empty map.
Nick
NagmaYasmin
Occasional Contributor III
Hi Nick,
You could use ArcGISTIledLayer.NoDataTileBehavior property (ImageTiledLayer.NoDataTileBehavior Property) to display the tiles even there are no levels defined. Basically that property will resample the tiled layer where the tiles don't exist.
ArcGISTiledLayer Class  --> NoDataTileBehavior.
"The value controls how a tile returning 'NoData' will be resampled."
Hope that helps.
Nagma
NicholasVolpe
Nagma, Thanks your reply on GeoNet
I wanted to double check I have this right, because I cannot seem to get
the behavior to change.
Below is the code I am using:
ArcGISTiledLayer localTiledLayer = new
ArcGISTiledLayer(new Uri(file.Path)) { Id = LOCAL_LAYER_ID };
localTiledLayer.NoDataTileBehavior =
NoDataTileBehavior.UpSample;
localTiledLayer.Name = "Tile package layer";
localTiledLayer.Id = "TilePackageLayer";
if (localTiledLayer.LoadStatus !=
Esri.ArcGISRuntime.LoadStatus.Loaded)
await localTiledLayer.LoadAsync();
MyMapView.Map.Basemap.BaseLayers.Add(localTiledLayer);
I have tried all the properties on the NoDataTileBehavior (UpSample, Show,
Blank). None of them have seemed to change the behavior. The tile package
which is saved as a TiledLayer to the base layers disappears when it is too
far zoomed out or too far zoomed in. Also, the Blank property does not seem
to do anything.
Nick.
dotMorten_esri
Esri Notable Contributor
Did you try setting the MaxScale on the tiled layer to something very very small?
NicholasVolpe
Thanks Morten! that worked for MaxScale. If I set the MaxScale to a very small number, I can continue to zoom in very close and keep the tile package displayed..
How about on the flip side of that? Can I keep the tile package displayed when the map is zooming out? I've tried playing around with the min and max scales, but no luck so far.
Thanks again for your help.
dotMorten_esri
I believe minscale has a limit, or you'll risk loading 1000s of tiles.
If you want to show data at more scales, you really should generate tiles for more scales.
SkyWatch
The link between NoDataTileBehavior and MaxScale is not obvious, so thanks Morten Nielsen. The documentation of NoDataTileBehavior could really need a note on this.
dotMorten_esri
Our SDK team has logged an issue to improve the doc. Thanks for the feedback!
NagmaYasmin
Hi Nick,
One thing I would like to mention about the NoDataTileBehavior, it doesn't resample the image tile at any scale. The purpose of this is that to enlarge the image and fill up the levels where no tiles are available.
Suppose, for a basemap tile layer you may not have the data beyond any specific level for some area but for some area you have the data beyond that specific level. NoDataTileBehavior enlarges the images of the area all over to the last level to have consistent display of the tiles. Hope that explains the behavior you are seeing at your side.
Best,
Nagma
Orca654
New Contributor III
I have similar issue to use map tile package inside the Explorer for ArcGIS.  I have a easy way to solve this issue by either edit the conf.xml inside the .tpk (zipped) file or provide special "service" file while you create map tile package.  https://community.esri.com/message/880732-make-tile-package-tpk-visible-at-all-scales
